2009 Genisis 4.6l w 6speed Aisin transmission (REFILL HELP)
qvidas1
Whats up everyone, My name is Q, I gave been a mechanic on aircraft,, helicopter, cars for 32 years, but currently getting my a$$ kicked on a Tranny refill. I've changed my tranny pan, but can't find refill instructions for my model anywhere . I spoke to service manager at 2 different dealers and they were clueless to the fill port location. Or how to do it. Need help asap! I've attached only plug location I see, which is drain and on the passenger side just above the pan. I can imagine pumping 11 liters of fluid into either of these without a hellava mess.
I don't think the 4.6 used the Aisin transmission- if my memory isn't failing me, the V8 was a ZF model (6HP26). The V6 used the Aisins. I am not a mechanic, but I did have a 2010 V8 Genesis and did a bit of research before buying the car. I accept that this could be wrong.
I'm dying to know what that giant (1 1/16") black bolt goes into on your 4th picture. I've been staring at this bolt for about 20 minutes while I have my car up on my lift and can't figure it out. It's right below the exhaust header for the driver-side cylinder closest to the firewall.
For the transmission fluid procedure, see page 3-7 in the Catalog linked below
https://www.thectsc.com/images/pdf/6HP26-28_Catalog.pdf
Your 4.6 uses the same ZF 6HP automatic as some older BMW. Therefore, the service process should be similar as well as the parts like the filter. The video shows were to fill it at about 2:00 and 19:00; the fill bolt is located on the case over the drain bolt.
