CVVT control solenoid replacement
johnny1593
2009 Hyundai Genesis 3.8 V6
California
Anyone have any DIY experience in changing a CVVT control solenoid on an ‘09 genny 3.8? Trying to avoid spending major $$$ at the shop if I can change this myself safely. Thanks for any info.
Found a small leak on mine, noticed rattling noise and rough idling but no check engine light warning. Thoughts? Pictures attached.2ECC3F3C-43ED-4620-A2BB-83127BFFDBB2.webp68116B9C-5D48-448C-B340-E443CDB411F0.webp3B0433DA-0DB9-432C-B9FD-B8C6BDA27CAE.webp
You’re the real MVP.
Thank you so much for helping me identify what it really was.
One small issue though about the links, its in Chinese. By any chance would you know where to find/purchase the oil seal compatible to my car?
I am a chinese live in korea.
You can use your car vin number to order from dealer.
this is the my car part number. my car is mpi 3.3 . contact the saler before buy it.
the 1-2 seconds rattle noise at cold start is the bad of CVVT phase.
rough idling: You need to clean the throttle body. and use CRC air mass sensor cleaner to clean air mass sensor.
blue: air mass sensor red: throttle body
very easy.
if your car rattle noise at cold start with 1-2 seconds then you need to replace cvvt phase.
rattole noise same as this car:
genesis bh GDI engine rattle noise at cold start:
