gpjlytham
2012 Hyundai Genesis 4.6L V8
Main issue: - A/C on with both drivers and passenger side temps set to low. The blower on full speed and the air temp out of the drivers side vent is 20+ degrees warmer than the passenger side. I don’t know if all genesis models have temp controls for each side but this car has that feature, so you could have heat out of one side and cold out of the other, but both are set to low with the a/c on.
What I think is happening: - the heater control on the drivers side isnt fully shutting off and that is causing the air to be warmer on the drivers side.
Questions: -
where is the valve or ? that controls the heat shut off for the drivers side vents?
What is the valve or ? name or part number?
Is this a known issue?
Any silent recalls?
Any instructions on how to fix this issue?
Other items of note: -
the air temp out of the vents goes up a few degrees when parked at idle
The air temps out of the vents drop a bit if you rev the engine while parked.
The air temps out of the vents are lowest when on the freeway with some revs
If you are on the freeway going fast and you put the car in neutral and let it idle (still going fast) the temp goes up a bit.
The engine temp never gets hot
The engine fan comes on when the a/c is on and the fan moves a lot of air
Questions: -
Any silent recalls?
