tomrhyne
I have detected a noise problem which I think is most likely in all 3.8 Genesis models. (Possibly could be in V-8 also.) I had the service manager at my dealer check with two 3.8 models on his lot and he was able to duplicate it. I would like some feedback from you as to whether you can detect the noise and, if so, what you think the source of the noise is.
Here is how you get the noise to appear: Drive at around 55 mph and switch to manual shift and then downshift to 7th gear. Accelerate slowly up through 65 -70 mph. See if you don't detect a high pitch whine around 62 to 65 mph. It then dies off as you move past this speed. I've found the whine is most evident if the car is under load going up an incline when you are accelerating up through the 60s. The whine appears to be coming from the transmission.
