Kdm5pointslow
- Jul 15, 2020
I got into contact with David Lee the tuner for Hyundai in South Korea. He is developing meThat’s the problem, engine has potential but no one can get into the ecu codes like a GM unit. Without that happening everything is minor increases except for NOS. LAP and others tried but little results. My unit was test bed for LAP, great guys to work with but only got 15+rwhp and only able to take advantage of the over rich mixture at top end built into the ecu. Gave up because potential costs vs sales to try to work it out. They were able to decode the V6 Stinger with a new ecu in 6 months with monster gains, so they know what they are doing. I found, to my suprise, that if I beat it hard and use 93 + oct boast I get trans to shift @ 7000 in first 3 gears. An engineer friend told me that the factory throttle body openings flow large enough up to 7200rpm and no need to enlarge. Same for injectors. Apparently there are engineering formulas for all this stuff. This is without adding supercharger/ turbo which would chg everything if you could get into ecu mapping.
The worlds first nitrous tune for the 5.0 tau. I gave him my plans for the car as well like headers and intake etc... and we decided to pull 2° timing at wot for a 125 shot. I suspect total na gains to be somewhere around 20-30rwhp along with a safe tune to spray 125. As well as a transmission tune. All together I’m looking at safely adding 155 hp to my genesis
