Need help with p0497 code
MrSheep
So I’ve been having trouble with my car lately I’ve change the front purge valve twice to see if the first one was bad after that I rest the engine light came back on after a day and a half then I changed the gas cap reset the light came back on after a day and a half changed the whole charcoal canister including the side piece it has the filter and reset the light a day and half pass the light comes on so now I’m not sure what it could be I’m not sure if it’s the black tubes if they have a hole on them but I made sure all connections where on well and tight on anyone have any idea or have same problem?
So I've been having trouble with reading internet posts recently when the OP doesn't use any punctuation it's really hard to read when there are no capital letters the use of punctuation really helps make reading long run-on sentences more readable when the poster is doing the stream of consciousness thing it's much easier to read when punctuation and capital letters are used I really could help with some links or something with the P0497 code but it's hard to read the OP and understand the actions taken and whether the OP actually looked for wiring faults or checked fuses or checked resistances across the purge and vent solenoids or looked for bugs clogging up the vent it's not too hard if you do a little research and oh yeah did I say punctuation and proper sentence formatting helps
Did you ever get the problem fixed I'm having the same issue with my Genesis, please met me know if you were able to find the issue.
