TJPark01
Went to the dealer to complain about some quality issues with the car. First the AM/FM wasn't working, found out it was the front key pads. Then I told them that there was a squeak from the seat, turns out the seat belt bracket is rubbing against the hard plastic seat bracket. (I actually knew about this and put silicone grease, which works for about a month, then the grease wears off. Third, was an issue with the lower air grill which was strangely a different color then it should have been, dealer said factory forgot to paint it. Lastly, the leather seat began to bubble, which I have seen in cars costing 4 times as much, but asked if they could do something. (asked a previous dealer and they said it was normal.) The pictures below represent before and after. (full disclosure the before picture of the seat is from a V6, forgot to take a picture, but my seat was doing the same, and many of you have mentioned this in V6 and V8 trim.)
All items were fixed, under warranty, they sent the grill out to be painted by a body shop, they sent the seat out to be reconditioned by an upholstery specialist. The tape was obvious and the keypad was a warranty item. Cost $0. Best service experience ever, thank you!
