Exterior LED light kit. Too bright?
Donovan_787
Car is a 2012 R-Spec Genesis
I want to use LED for the following....
-daytime driving light (H7)
-foglights (H8)
-reverse light (921)
-license plate light (6418 36mm)
I don’t want to it to be too bright to a point where it will blind oncoming traffic. I also don’t want it to generate too much heat. Which brand do you recommend. Can someone recommend a good brand?
Go to Headlight revolution on YouTube, they are one of the few lighting companies that provide testing of thousands of bulbs to find the good and bad. Most important is to find a bulb that matches the factory light pattern the closest and also has only two bulb sides. Do not buy bulbs with led's everywhere for headlights, they have terrible glare and headlight performance.
I'm going to buy the H7 led bulbs for my highbeams - GTR Lighting Ultra 2 bulbs. The V.4 bulbs are also a good choice too. They have a 20% off sale right now.
Here a great list:
Highbeams - GTR Lighting Ultra 2 H7: GTR Lighting Ultra 2
Foglights - Diode Dynamics SLF Diode Dynamics H8/H9/H11 SL1 LED Headlight (pair)
Reverse lights - VLED's HIGH OUTPUT WHITE 6 LED 921
License plate - VLED's WHITE 360° LONG LIFE 24 LED 38MM 6418
Here a great list:
How did these LED bulbs work for you? Were they any better?
The GTR Lighting Ultra 2 are more than impressive than I was expecting for use in my high beams. The light output is unreal and is much brighter than my '18 Outback LED highlights when using high beam.
I purchased the S.V.4 bulbs for my wife's 2012 Optima high beams and they are also very impressive, can't go wrong with either bulb choice.
Thanks I will look into them.
I recently purchased led car lights for the car's interior and chose the VONT company that my friends advised me of.
I recently purchased led car lights for the car's interior and chose the VONT company that my friends advised me of. I think you should pay attention to the LED light from this company, as far as I know, they do everything from ordinary LED bulbs to LED lighting for cars. Watch some videos on YouTube about this company and its products, and I think you will find what you need. And by the way, I usually order LED lighting from Amazon, and I advise you to order only from there because there is much more choice there, unlike other online stores. Good luck to ya. I hope it helps!
