Bryandowen
- Dec 28, 2016
- Location
- Northern California
- Genesis Model Year
- 2015
... That's sort of exactly what I'm doing. Thanks.
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
I absolutely dread taking my car to any shop for a non-routine issue. I somehow attract the most esoteric car problems on earth, and I've spent way too much money having a shop tell me that my problem isn't a problem, or that they couldn't reproduce it.I'd be very surprised if the dealer could track this down.
Hello, BryanI started my 2015 Genesis (5.0, Ultimate package, ~104k miles) today, and I noticed all sorts of weirdness out of the blue:
- Check ECS
- Check LKAS
- Check BSD
- Check PSB
- Check AEB
- Check TPMS
- Blinkers and hazards don't work
- Speedometer, tachometer dials don't work
- Shift indicator is blank (there's a box displayed, but nothing inside of it; shifting into Drive yields nothing)
- Power steering is harder than normal (but not completely dead)
- Radio works, but gives "Battery discharging" warning as if the car is not running
- In reverse, I see the indicator showing where the car is headed, but no camera image
I'd seen something like this happen before, and turning the car off and back on fixed it. This time, no dice. I took the car for a short drive then parked and turned it off and back on, and still no dice.
The only possible clue I can fathom to any of this is that a few weeks back I hit a pothole driving through Vail, Colorado, and my Check AEB indicator came on and has stayed on since. That I assume is due to some misalignment or loose connector or even damage to the AEB sensor, but I can't imagine that would somehow become aggravated over time to cause all these other issues. Maybe I need a more active imagination. With everything electronic, nothing should surprise me I guess.
I saw talk about an inoperative brake switch causing similar issues, but I've verified that the switch works and my brake lights come on. I also checked the "3 MODULE" fuse under the hood and it's fine. I'll start checking other fuses, but would be tickled if someone saved me a goose chase because they have a good idea what to look.
Thanks y'all.
-Bryan
That's unfortunate. You have a lane departure warning as well. These systems are inter-dependent in interesting ways, so it could be a single sensor is acting up, and at a granular level your computer knows what went wrong, but it bubbles that message up in a way that lets you know which systems are now disabled, but doesn't point you at the problem. I wish there was some "press OK for more detail" technique that would tell you what actually triggered the cascade of messages.OmG, It happened to me on mother's day with my family at the restaurant, Had to tow the car to local dealer and got the car back in two days.
when they tested next day, it was normal. No solution provided. they told me to bring the car back when it happens again.
Guess what. it' happened today morning 5/24/21 front of my home. So. it has happened to me twice within two weeks.
Any luck /?Got the car back after two days. I guess they didn't even checked my car until I stopped by for an update.
I did have the bad feeling about the dealer since I didn't purchase the car from this dealer.
I felt service advisor was having a bad day while I was asking for help, didn't even listen to what I was explaining and didn't want to take any document I created. I had the video clip of what was happening.
They did found the CODES C1611,C1812EPB,C1812EPS, C1812SCC, C180B, C181287 & they had to contact the Tech line for the issue.
If Service Advisor took the document I gathered, He didn't need to call me for explanation, I told him I'm going back to the dealer I purchase the car.
I did waste my time and not willing to purchase my next Hyundai car from this dealer even though it was close by from my home & work.
I will let you know any updates when I go to the dealer I purchase the car. Hopefully they can found out the issue.
It is never wrecking, whenever I start the car. Scare to drive out of town or visiting any local store.
I had an issue with check PSB along with the temp gauge going blank, I replaced the fuel pump module and its all good now. It cost me like 180 to replace, I would gamble and just replace that first.I started my 2015 Genesis (5.0, Ultimate package, ~104k miles) today, and I noticed all sorts of weirdness out of the blue:
- Check ECS
- Check LKAS
- Check BSD
- Check PSB
- Check AEB
- Check TPMS
Thanks y'all.
-Bryan
I have replaced the fuel control module (problem went away for but pop up occasionally about 2 months )now the issues is back , I've already change the engine harness its becoming annoying and im in the Bahamas this car is stressing me out,,,, i keep throwing money into this car its 2015 , Genesis 3.8 base RWD with the sunroofI had an issue with check PSB along with the temp gauge going blank, I replaced the fuel pump module and its all good now. It cost me like 180 to replace, I would gamble and just replace that first.
Please keep me posted as into what is the outcome I am having the same issue but my car is not equipped with LKAS & PSB.Hi guys, Today it happened again this morning, I will give you an update when I get back home today if it works or not, It does come back to normal after a period of time, that's why dealer ignored my video. It really sucks. It's my third time since 2021 May
Took mine to Hyundai , they said the Hydraulic Unit needs to be replaced . That’s the main issue that causes all other sensors to react !I started my 2015 Genesis (5.0, Ultimate package, ~104k miles) today, and I noticed all sorts of weirdness out of the blue:
- Check ECS
- Check LKAS
- Check BSD
- Check PSB
- Check AEB
- Check TPMS
Thanks y'all.
-Bryan
