MrXperc
- Jun 13, 2018
Hi Guys, so I finally decided to install a Nexus 7 in my genesis for navigation purposes. I do a lot of driving in town, and the stock navigation wasn't just cutting it due to the outdated maps and lack of support by Hyundai. This might be the best way to have a tablet mounted in the tech package since you can have it on when driving and take it home after your done. I used two Scosche mount plates bought from amazon. I stuck one plate on the tablet and the other on the dash (Pictures are attached for more context). I went to home depot and bought the smallest L brackets I could find and epoxyed two neodymium magnets on both ends, as seen in the picture. Make sure to get neodymium magnets for the stronghold. I haven't had the tablet move or vibrate once, even going through speed bumps and rough roads. You will have to adjust the L brackets using pliers so that the tablet is flush with the dash. This will also make the tablet more securely fit in the navigation panel area. One Neodymium magnet sticks to the mount plate on the tablet and the other to the mount plate on the dash. Here are some pros and cons of this setup.
PROS:
Google maps for navigation
Easy to mount and take it off
Use for media consumption
Easy to install.
CONS:
Blocks View to the backup camera while reversing
Sun Glare makes it very hard to use in the afternoon. (trying to find a fix for this. Anti-glare screen protector and playing with contrast and brightness didn't fix the problem)
The tablet battery isn't that great, and it cant be charged while using but can be easily plugged in after use. I have to charge it every couple of days.
I might buy a new tablet with similar dimensions to Nexus 7 as it fits perfectly in the dash with a better battery that is more current and better screen for my purpose.
Let me know guys if you have any suggestions or any questions. See attached pics.
PROS:
Easy to install.
CONS:
