The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
kdmwarehouse.com
Normally I remove all advertisements but with so much bare real estate between the tails It needed something to balance/tie in the open space. That is why I went with the Wing that I also modified to my liking (KEYWORD ➼ "MY")...I respect your or anyone's opinion. It's all good.Idk... IMO, The genesis lettering looks better.
i debadged the “GV70” and “3.5T“ much cleaner
The emblem looks out of place back there, to me. Or maybe it’s just not centered and it’s throwing off my OCDGenesis logo is between the two tail lights. That emblem is across the top part of the tail light.
So you just use a fishing line to pry off the name plate? And it won’t mar or damage the paint?It’s just double sided tape. Use fishing line and it comes right off.
Wow ty. That looks awesome. Is that rear badge larger than the one on the hood? Where did u purchase it?
kdmwarehouse.com
Can u post a pic plsIdk... IMO, The genesis lettering looks better.
It's possible to mar the paint with string. If you pull from say the top of a letter towards the bottom you risk lowering the bottom of the emblem while the top is raising causing the bottom to gouge into the paint. Same for going at whatever angle. Been doing this for many years, I've seen the damage done. Almost always because of not applying something like the 3M GPAC around the rubber double-sided tape while holding a rag to catch the excess. It becomes almost to the point of just slipping off. I can do it as can others W/O the 3M but it's not worth the risk...IMO!So you just a fishing line to pry off the name plate? And it won’t mar or damage the paint?
Ok ty.
hmm I wish I can practice it before making the attempt…
So the GPC won’t hurt the paint?
As always TY. So the 2-3 coats of wax, u apply that before putting on the emblem? I applied ceramic on mine, so I wonder if I apply sealant, then a couple of ceramic applications in that area before putting on the emblem?I squirt carefully around the emblem while holding a rag to catch the excess. Once removed I wipe all the glue residue off with 3M on a cloth. I use a little soap and water to clean the area then apply 2-3 coats of wax. The 3M will not dissolve or mar automotive paint that has been properly aged. I use it all the time around the house in addition to automotive projects.
No.As always TY. So the 2-3 coats of wax, u apply that before putting on the emblem? I applied ceramic on mine, so I wonder if I apply sealant, then a couple of ceramic applications in that area before putting on the emblem?
