nearwater
I used blue painters tape. First I ran a piece up from the grill center line to find the center on the hood.. Then I created a box just a tiny bit bigger than the wing...measuring up from the grill on each side. Placed the wing tips at the corners of the box and lowered it into place. I measured and moved the tape a bunch of times before feeling comfortable enough to attach the emblem.
P.S. I let the curvature of the emblem "show" me how high to mount it (about 1.5" above grill.) The emblem curves more at the front...kind of like a bird's beak. I slid the emblem up and down the hood till it's bottom edge best matched the curvature of the hood. It had more surface contact and was "stickier" when sliding through that location.
Very smart way of doing it. I was thinking of aligning the center by using an elastic rope/thread from the center of the grill to the center of the hood that meets the wind shield.
But that box thing is a good idea.
I'll try to make a 1:1 scale of the actual badge and use that card board to determine the location.
Was it exactly 1.5" above the chrome piece(attached to the hood)?
Would you mind measuring it again when you get a chance?
Thanks again, Disaster.
BTW, I've seen maybe 4 Genesis'(3 V6, 1 V8) around Troy area within the past couple weeks.
Dan
