JimInNashville
- Feb 25, 2010
Very true, but obviously related to how much gas is in the tank when you fill it. We rarely fill the tank if it is more than a quarter full (unless we are planning on a trip.) More often, I fill the tank with less than 100 miles left on it...often with less than 40. We also always fill at the same station...though not necessarily the same pump, but common pump design does reduce variability.
The 3.8L has a 19.3 gallon tank. Our usual refill is 16-18 gallons. Worst case for us then would be .5 gallon error on 16 gallons, 3%. The difference we were consistently seeing between estimated and actual was about 4%...and that was pretty consistent and NEVER was the estimated mileage less than the actual.
Having said that, there are some other variables that make the mileage I'm getting not a great longer term estimator. The following are some of the variables I can think of, vehicle break-in...still have less than 3K on the clock, weather...as temps warm up, mileage will change, tires...going from winter to summer tires will effect mileage, getting accustomed to vehicle...driving will change after get used to vehicle.
Point well taken. I should add that, if you maintain records, none of this matters once the miles add up. Eventually, if you record every gallon you put in the tank, you'll have an accurate mileage estimate. On the other hand, for a single fillup, you'll obviously have less sampling error in the mileage estimate if you let the tank get more empty. (A potential side benefit -- on average you'll be moving less weight, since you'll be moving less gasoline in your tank. This may actually yield a slight increase in gas mileage.)
BTW, comparing real mileage with the trip computer: My experience concurs with yours. My trip computer overestimates the mileage, probably by about 1 mpg.
