Gv70 Show off your Mods to date.....
AleonGV70
Member
Genesis GV70
Hello and Wassup my fellow Gv70 owners. Drop some pics and be proud owners of a nice crossover Sport SUV.
1. Tint windows front and sides
2. Carbon Fiber Wing
3. Replace back letter with Turbo
4. Remove Gv70 and Awd emblem
5. Add blackvue dash cam 900s
6. Install blowoff Valve
7. Install Lowered Storm Springs
8. To be continue
20211215_120828_resized.jpg20211215_113951_resized.jpg20211215_115703_resized.jpgScreenshot_20211214-070921_Gallery.jpgScreenshot_20211214-070933_Gallery.jpg20211215_115958_resized.jpg20211215_114027_resized.jpg
8. To be continue
View attachment 42144View attachment 42145View attachment 42146View attachment 42147View attachment 42148View attachment 42149View attachment 42150
Did you install the sub yourself? And does it sound good? My past experiences are that the factory head unit always sounds worse with audio upgrades. A new HU always sounds good, but not willing to do that on this car, as I love it.
Also my first turbo...so can you explain what the blow off valve's benefit is?
Hi, yes my bro and I install the sub... the 16 speaker lexicon system sound really good with the sub....thump hard as F#&k. Tap the stock amp subwoofer line with an audio controller then to an amp to run the bigger sub woofer added. The blow off Valve gives you that swoosh sound when releasing pressure from the turbo...really help the turbo and longivity. Also, let's people know your car is turbo if they try something when accelerating.
I am assuming you ran an amp as well for the sub? How hard was it to get to the back of the stereo? Or is there some other crazy way to tie in without tearing the dash apart?
Hi, yes my bro and I install the sub... the 16 speaker lexicon system sound really good with the sub....thump hard as F#&k. The blow of Valve gives you that swoosh sound when releasing pressure from the turbo...really help the turbo and longivity. Also, let's people know your car is turbo if they try something when accelerating.
Not hard at all, amp is back passenger side cargo panel. Pretty easy to get to and take apart just be gentle with all the clips removing it. You will tap the stock sub woofer line from amp to a audio controller and then to another mono amp to get clear power.
8. To be continue
Also. How do you remove the front badge without damaging anything?
First use masking tape and stick around the emblem.... then I use a heat gun or blow dryer to heat up the emblem....make sure it just heat up enough to slowly peel... there is 2 placent tab on both side...just slow pull off. Should be simple. Very simple removal.
Sorry to keep harping on this, but if you tap into the stock amp, is it just the power to run the extra added amp? Just worried about burning on the stock amp if it is also drawing wattage from it to power the new one. Hopefully I am making sense here. Installed many subs / amps.
No u gonna tap stock sub woofer line to get signal only with an audio controller... you will need another amp to power the external sub woofer your adding...the stock system stay untouch.
Appreciate it😉
Merry Christmas.
I wonder if Santa will bring me a “thump hard as F#&k” sub.
Aimban front seat rear covers
EBay … type in GV70 and scroll through the listings.
8. To be continue
Looks killer. How much did the Storm springs lower it? And how much did they run?
Also, what audio controller did you use and did you happen to take a picture of the amp after tapping the lines (to save me having to find the wiring diagram and figure out which lines are which lol)
How did you install these so nicely? I guess I am less patient when it’s this cold. Any tips?
