Easy Access
jtharris
Own a 2010 Sedan, 3.8, with Premium package. Could someone tell me if, upon turning off the engine, the steering wheel is supposed to move up and back and the seat rearward for easy exiting? In my car, only the steering wheel moves.
And, upon reentering, sometimes the wheel returns to the memory set position when starting the motor, and sometimes it does not. It will always do so if the start button is pressed once without depressing the brake pedal. What should be happening? Is there a way to reset the system to make this work properly.
Thanks,
Regie
I have the same as you, with the same result. I believe only the Tech package has the seat retraction feature.
There is a TSB on the steering wheel limit switch which seems to be responsible for the tilt/telescoping problems many members have experienced. I had mine serviced a couple of months ago and the problem was resolved, at least so far.
Please, what is a TSB?
And what kinds of probs are you aware of?
Thanks
