The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
do not know if it can be installed on 21--probably can. I installed lighted scuff plates from Hi Motors in South Korea.. You can find them at Himotors.comDoes anyone know if the illuminated Door Scuff Plates option available for the 2022 GV80 can be installed on the 2021 GV80?
Thank you I will look into it.do not know if it can be installed on 21--probably can. I installed lighted scuff plates from Hi Motors in South Korea.. You can find them at Himotors.com
Thank you! I appreciate the infoContact the seller. Ask if the wiring is in place for plug and play installation. Otherwise, you will have to wire it.
HI-MOTORS
Accent 11~,Azera 12~(Grandeur HG),Azera 06~11 (Grandeur TG),Elantra 16~(Avante AD),Elantra 14~15(New Avante MD),Elantra 2010~2013(Avante MD),Genesis 2014~,Genesis Coupe,Genesis(2010~2013),H1(Grand Starex),i30 2012~(Elantra GT),I40 2011~(Saloon),SantaFe 2013~2016(ix45),SantaFe 2010~2012,SantaFe...hi-motors.com
Manufacturers do strange things. For example, I installed plug and play lighted sill plates in my ‘12 Genesis. The plug and play wiring fortunately was there so no wiring was necessary. Installation took me 20 minutes.Thank you! I appreciate the info
You right about that. Hopefully I get luckyManufacturers do strange things. For example, I installed plug and play lighted sill plates in my ‘12 Genesis. The plug and play wiring fortunately was there so no wiring was necessary. Installation took me 20 minutes.
Owners of ‘15 Genesis models weren’t so lucky and their cars came without the plug and play wiring. They could still install the LED sill plates, but also had to run the wiring. That certainly reduced aftermarket sill plate sales.
Do you have a part number? I purchased a 2023 GV80 and was told no OEM option for an illuminated door scuff plate. I have searched the web high and low and could not even find a part number / called a Genesis parts dealer and the couldn’t find a part number for any year. Any help would be appreciated.Does anyone know if the illuminated Door Scuff Plates option available for the 2022 GV80 can be installed on the 2021 GV80?
yes it does and they are available for both front and back doors. They turn on and off with opening the door. Mine were installed with a tiny 1/8 inch hole drilled into the side of the sill plate to get to wiring. If you look close when you see them you can see about 1/8 inch wire showing, but no one notices.I believe the third party one from HI-Motors does require wiring.
Do you know where they tapped into the power from?yes it does and they are available for both front and back doors. They turn on and off with opening the door. Mine were installed with a tiny 1/8 inch hole drilled into the side of the sill plate to get to wiring. If you look close when you see them you can see about 1/8 inch wire showing, but no one notices.
Do not know specifically, but it has to be the circuit that when you open the door the inside lights go on as well as the sill plates. If you know which wire controls those, it probably is that. The shop that did my plates and retractable, lighted running boards has a computer subscription to a company that shows all the wiring diagrams to cars-that is how he knew what wires to use.Do you know where they tapped into the power from?
T6F69AU000Do you have a part number? I purchased a 2023 GV80 and was told no OEM option for an illuminated door scuff plate. I have searched the web high and low and could not even find a part number / called a Genesis parts dealer and the couldn’t find a part number for any year. Any help would be appreciated.
