The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Well, you're in luck... Just read through this thread and you will have your solution... A few possibilities.... --- But if I were in your shoes after a 1 week purchase, I'd let the dealer that sold it 'own' this problem.Just purchased 2021 GV80 1 week ago...and yep sure enough....Sirius XM is frozen up, can't change channels, not even to a radio station.
I had this problem. Same model. Tried replacing the radio first. No luck. It is an issue between Sirius and the software. I changed my Sirius subscription to music only and it was fixed.The 14.10 upgrade is very buggy/poor. I've done 4 previous updates with no issues. Subsequent to installing 14.10 last week, I can switch to/play XMSirius radio. 5 to 10 minutes later channel controls (screen, jog or steering wheel switch) become unresponsive. I can switch to other sources (AM/FM etc.) and sound/controls work. Attempting to switch back to SiriusXM sound to goes away for 10 seconds, screen does not switch to XMSirius and it returns to original source (e.g. FM radio) and FM audio resumes. Stopping car for 5 minutes and restart restores XMSirius functionality, but issue re-occurs. Pushing the DIS/Navigation reset button is on my troubleshooting to do list.
I also notice the screen periodically returns to home screen without any input from me.
MODEL / MODEL YEAR:
2018 G80 (9.2-inch HD navigation system with DIS Multimedia Controller)
PART NUMBER:
1411SP2_DHPE
MAP VERSION AFTER UPDATE:
NAM.13.47.50.610.001.3
I had the same problem. Replaced the radio. No help. It is a problem the new software has with Sirius. I changed my Sirius subscription to music only, omitting all other services like traffic, data etc. Problem solved.Well, you're in luck... Just read through this thread and you will have your solution... A few possibilities.... --- But if I were in your shoes after a 1 week purchase, I'd let the dealer that sold it 'own' this problem.
I am out of USA, did not even had any sirius subscribtion, it does not work at all here. The screen is stuck on logo and restarts after every 25-30 seconds. Though radio is working but you can not change channels, only volume.I posted this once but I don't see it so here it is again. I have a 2018 g80 sport. Had these same problems . Changed radio. No help. The problem is the current Genesis software has a conflict with Sirius. Change your Sirius subscription to audio content only without any data such as weather, traffic etc. Problem solved.
Just took delivery on my 2021 G80 Yesterday. was on my way home and just a few miles from the dealer when Navi locked up. Returned to the dealer immediately and they said it needs an update. Gave me a loaner (G70) and I await the return of my car later today.
Will try and post my outcome.
They (Sirius XM actually) certainly fixed the issue this thread is about on mine....From this string, it seems that Genesis cannot fix this issue.
It does not sound like you have the problem this thread is about at all. It sounds like you have a failing entertainment/nav system, which is not unheard of for the 2015 year model. I wonder if the whole thing needs to be replaced, or if you could get by with just replacing the hard drive?I believe I am having the same slow screen response/freezing with my 2015 3.8 Ultimate and of course I had the 100k extended warranty but now have 115k on it. I do not have XM. Should I do the rest thing on the radio first and hope that works? Mine can work perfectly for months and then act out for weeks and shutting the car off and turning it back on does nothing. I have not added XM pat the 3-month trial...HELP!!
Did you try this (quoting from conanbarb reply earlier in this thread). This worked for me. I ended up trading the car in for a 2021 G80 due to high used car resale value.I have a 2018 G80 Sport 3.3T and a few years ago it had issues with the XM radio freezing up resulting in a radio whereby no channels could be changed and the buttons for the other functions were unresponsive. This was supposedly due to an incompatibility issue between the Hyundai software and an XM update. The problem was finally corrected when either Hyundai or XM generated a software fix. This problem lasted a few months and many owners from all over the country were having the same issue. All was fine until 3 days ago and now I am experiencing similar issues but much worse - frozen XM channels and unresponsive buttons, frozen navigation, etc. Anyone else having radio issues???? I plan to call the dealer tomorrow, but last time they were clueless until a bunch of owners reported this issue on this forum. One more thing, when I turn off the car, the XM radio will work for a bit and then it will freeze up again (along with the other functions such as navigation, etc). If this continues, I will consider getting rid of it...
