Hello all,
Crossing 50,000 miles
*I have 10k,20k, and 40k updates where I wax poetic about the Genesis, so I'll keep this one brief*
- No squeaks, rattles, problems whatsoever
- Oil change every 7500 miles (Mobil 1 0W-30 Synthetic - excellent stuff that reduces the startup lifter noise that is common on cold mornings)
- Cabin filter replaced at 30000 miles. Fairly easy to change.
- Wiper blades changed at 40000 miles. Easy as pie to change.
- Air Filter changed at 40000 miles. Easy as pie to change.
- Tires replaced at 40000 with Michelin Pilot Sport A/S. Excellent tires with more grip that the stock Dunlops with a VERY slight improvement in the already excellent ride quality. Very pricey though and it seemed like they took a while to 'break-in' as they were initially very stiff.
- Paint is in Excellent shape
- Leather seats and interior panels look brand new. No severe cracking on the bolsters of the leather seats. I condition them every so often with Lexol Conditioner after using Lexol cleaner to clean them.
- Rides Beautifully...only turns a little 'crusty' over rough surfaces. The most important thing in this regard - TIRE PRESSURES. I've had good luck setting the rears 1 psi lower than the fronts, but DISCLAIMER: Follow Manufacturer Recommended Pressures
- Very misleading info from Owner's manual vs. Dealership vs. the 'Quick Start' Genesis guide....for example owner's manual states 'Fuel Filter' and 'Fuel Air Filter' should be replaced at 37.5k miles. This is not accurate - these do not ever need to be replaced. Another confusion I ran into was the tranny fluid - dealership said it needs to be replaced at 60k but I read somewhere else that the fluid was 'lifetime' which is typical of modern auto trannys.
Comments/Compliments:
'Riding in a jet'
'Spacious' 'Huge'
'Quiet'
'Serene'
'Majestic'
'Smooth'
Conclusion:
An Absolutely BRILLIANT car. Absolutely stunning. I'm an automotive engineer and this car is a marvel. I own/owned Audi, BMW, Acura and have extensively driven Lexus, Infiniti, Saab (over 3000 miles in each at least). A truly outstanding job well done. Much like 911 owners who swear by nothing but 911s, I'm an 'Genesis' man for life. Check out that laser welded roof, the foam insulation in the door hinge area, the triple door seals, stiffer structure than a 5 series or E class, more interior room than a LS460, headlight cluster detailing, tighter panel gaps that a S class, LS460 and 7 series........absolutely Brilliant Stuff.
I wish you guys many Happy miles of motoring
'Riding in a jet'
'Spacious' 'Huge'
'Quiet'
'Serene'
'Majestic'
'Smooth'
Conclusion:
