dtevescar
Anyone else have the horrible "rattling" usually first start in the morning? It will also occur during short trips around town. Dealer response??? It is perfectly normal!! Well, I am embarrassed when anyone hears that noise, and turns their head to see who the fool is that wants to drive that old rattletrap??? I swear, it sounds like the junkyard's resident tow truck. After some research, I have found the noise is caused by a loose timing chain, whose chain tensioners have lost oil pressure from the piston that holds the tensioner against the timing chain, when the engine is shut down. I understand that Hyundai has done a redesign of the piston actuators, and the new design does not lose oil pressure when the engine stops.....however....as is usually the case, dealer is in total denial of the problem. I wonder if the timing chain breaks, as a result of the slapping against the chain housing, will the warrantee be honored? There are several utube videos about this issue, and they say what it is, and show the new design for the chain tensioning devices.
What do you think??? Sell the car before it breaks?? Or just cringe every time you start it, hoping no one will look??? (which is what I do now)
