The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
200A service has been pretty standard in the US for many years now. My house built in the 1970s has 200A service.A 200A panel? I’m envious.You must be in a very new home.
Lol I am lucky indeed. House is new-ish, built in 1999.A 200A panel? I’m envious.You must be in a very new home.
I guess the standards in Canada are different. My house was built in 2008 and just has 100A service. Panel is rated for a max of 125.Lol I am lucky indeed. House is new-ish, built in 1999.
Great advice. Even if a charger, or any appliance, is rated up to a certain amperage you shouldn’t be operating it above 80% of the breakers capacity. I ran a new circuit off a dedicated 50 amp breaker from my main panel and am using an EV charger that can operate up to 50 amps but has the capability of dialing down, which I wanted. So I’ll run my charger at around 40 amps, otherwise I’ll risk tripping it.I don't have any experence with an EV, but my experience with having a ceramics kiln can add to this discussion. I'm in the US, and we have transformers, so this doesn't apply to other countries.
My kiln requires 50A. Here in the US, or at least here in Texas, the utilites can supply up to 200A. When we got the kiln, we had a 60A circuit added for it. A circuit needs to have higher capacity than the maximum load for that branch. What happened the first time we fired the kiln was that it blew the breaker on the transformer out at the street. We called the electric company, and they said that even though they can and will supply 200A, most houses don't need more than 100A, so they normally use that size transformer in order to save money. However, they are willing to, and did, replace the transformer with a 200A one.
And, as someone else pointed out, the capacity of the panel has to be checked. Some panels might be able to carry a larger load by replacing the main breaker.
It's worth it to hire a licensed, bonded electrician. High voltage wiring can easily be dangerous if it's not done properly.
I had a quick look for what the cost would be (Canada), EVSE ~$1000, wireless ~$5000. It’s a pretty big difference for one to walk around the back, open the door & plug it in.I am in the UK. I have ordered a Sports Plus and I am advised the car will be delivered to me in October.
Nearer the time. I will endeavour to find out the price and the suppliers of the Wireless Charging System, as in the video below @ 12 minutes…
Hopefully it's not too expensive. It does look to be a great way of charging the GV60…
Paul Choo…
No issues at the car. You’ll need to make sure you have EVSE that is built for the outdoors, though.More practical question for those parked outside 24-7 without any cover, is there any issues with the car plugged in when it's raining? I assume no.
Maybe things have changed post-COVID, but I remember entry level chargers being available for significantly less than $600 US. I paid less than $1000 for a 40A Wi-Fi-enabled unit.Given the high prices of 40+ amps wall chargers online US$600+, I'm highly considering buying a used Tesla Mobile Connector. They are officially only US$200 and you can change the adapter plug to any NEMA plug imaginable. Then you can buy a Tesla to J1772 adapter for about $150 so total cost is $350 all in. The only downside is the Tesla mobile connector is limited to 32amps, which doesn't matter if you're just overnight charging. But what you gain is portability (take anywhere) and universal plug adaptability, not to mention half the cost of other permanent wall installations. Having the Tesla to J1172 adapter also gives you max flexibility while traveling since many hotels and destinations have Tesla wall chargers for customers so you can plug right in.
There are definitely cheaper Chinese brand wall chargers on Amazon that are not UL listed and I would not trust them even if they are $300. For any name brand Chargepoint, Lectron, EVGo wall chargers, they are typically $700+. Yes you do gain wifi control, but you can already do that within the vehicle.Maybe things have changed post-COVID, but I remember entry level chargers being available for significantly less than $600 US. I paid less than $1000 for a 40A Wi-Fi-enabled unit.
I just ordered a Tesla adapter for flexibility while on the road. I think you might find what you’ve suggested a little bit of a hassle. From what I’ve seen, you need to wait 30-60 seconds after connecting the adapter to the Tesla unit before connecting to the vehicle, which would make regular use at home a bit of a pain - unless you left it connected at home, which then negates your on-the-road flexibility.
Ricky,I have to do some research - unless anyone here is in the same boat and can provide any advice. I have solar on my roof with a max capacity of 8.16kWh generation. I'd prefer to prioritize charging from solar and only the excess goes to the grid, for no other reason than to brag that my car is running on 100% renewable energy. Any excess generation gets sold back to the grid at the same price I purchase it for, so there's little by way of cost considerations whether I charge at night or during the day.
