Brake line recall on my 2015 Ultimate?
Aurally
Massachusetts
As I scheduled for my ABS fuse recall at the dealer, they informed me that there is a second recall which involved replacing the brake line. It is a 1-3 day job because the entire read end needs to be taken off to get to it.
I'm a bit puzzled because I cannot find any recalls on-line, neither do I recall this being discussed here. Did my dealer mess up the Genesis with a different Hyundai model?
There are a number of threads on here about that very thing. Search for them. It is serious, and you certainly want to do it. Members have threads on here about losing all or nearly all braking due to the lines failing.
You can also put your VIN in at the NHTSA recall site, and then read about this recall.
I believe that I read about a brake line recall for northern states that uses salt treatment on roads due to corrosion issues. It may have something to due with brake lines that were not properly coated for use in rust prone states. It may have just been a certain batch of brake lines under certain VIN numbers that were flagged as not being properly coated and not an wide spread incident.
One of my GM cars had corroded brake lines when I lived in CT. It was on me. Let them do it as long as it is free. You could end up needing them later at your cost.
