Memory Fuse
Paulroger
I have seen many discussions concerning discharged batteries. How many of you are aware of the following in the manual?
" Your vehicle is equipped with a memory fuse to prevent battery discharge if your vehicle is parked without being operated for prolonged periods. Use the following procedures before parking the vehicle for prolonged periods.
1. Turn off the engine.
2. Turn off the headlights and tail lights.
3. Open the driver’s side panel cover and pull up the memory fuse.
Just thought you should know! :rolleyes:
For those of us with bad eyes, I wonder which one is the memory fuse?
For those of you unfamiliar with the concept of actually reading the manual, I have attached a picture of the fuse involved. The same picture is available in the manual (I couldn't copy it). I think this is the same fuse referred to in another thread that was loose and causing problems with starting.
That fuse shown here in the yellow bracket was the culprit that caused my car not too start without the smartkey plugged in, and all the electrical to not function including the Nav screen. It was just a tad bit loose.
So u mean to tell me before I leave my 2012 Genesis sedan 4.6 parked for over weeks to take out that fuse so my battery won't be dead..
