The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Describe the sensation/stutter. Are you flooring the gas and it takes too long to deliver torque?Did that too
So with light acceleration the car jerks back?Its during the shift change, I can stop it with heavy acceleration
I thought the trans are sealed...never to be changed. I have a 2012 Gen 3.8L.How many miles on your vehicle? Ever changed the trans fluid?
I just tried to make an appointment with the dealer and they gave me one in 6 weeks from now!!It is still possible to drain/fill the trans fluid even if the manufacturer claims it's a "sealed" unit.
If you do a traditional drain/fill, you'll get just under 3qts drained. If you decide to replace the trans pan, you'll be able to replace just under 6qts.
The improvement in shift quality will be immediately noticeable. Since you have a 2012 model, you may already have well over 100K on your trans...so I would talk to your mechanic about replacing the fluid before moving forward.
Just an update on my situation, after complaining to Hyundai on four separate occasions, and 2 dealerships, they determined nothing was wrong.Anybody experience transmission stutter at gear changes? I have a 2013 3.8l sedan. The best way to describe the sensation, the gear changes are at too low an rpm. Its avsimilar feeling when you are driving a standard, and its in too high a gear
Wait, what? What is an $8 can of friction modifier? And how did the mechanic get it in the transmission?Just an update on my situation, after complaining to Hyundai on four separate occasions, and 2 dealerships, they determined nothing was wrong.
I guess I am the crazy one here.
I decided to go visit my neighborhood mechanic. He wanted as much detail, as I was willing to share.
One day later, and an $8 can of friction modifier, in the transmission, and problem solved.
Extended warranty my a@!!$$.
I took my 2012 5.0 R spec (51,000mi) for oil change. Afterwards the shifting became harsh. Like it didn't know what gear to pick. In higher gears it felt like it slammed into gear. Big kick.Wait, what? What is an $8 can of friction modifier? And how did the mechanic get it in the transmission?
My 2014 5.0 w/ 98K miles has had all kinds of strange transmission issues since around 20k miles. Took it to 2 dealers on 3 visits always told "that's just how it drives - see if you can find another 5.0 to compare it to". Basically the car feels like it "rocks" back and forth when driving around 30 mph and trying to modulate speed in traffic - almost like engine mounts are loose. Then when letting off the gas and getting back on it, like when somebody pulls in front of you, causes the RPMs to surge a bit with a big punch like a mild rear end collision. And lastly when hot and making lots of short trips (think errands), shifting from park to drive the transmission makes a double-punch feeling. Like a double engagement, but strong enough to make the car feel like it got bumped.
I'm on the original fluid and not under the warranty (bought used w/ 8k miles), so I'm looking for an independent mechanic to take it to get looked at before it becomes a bigger issue.
I've never heard of anything like this, but I guess it's a possibility. It doesn't trigger a check engine light and plugging in an OBD-II reader doesn't show anything. Are there other codes that are collected/read by Hyundai specific readers?I took my 2012 5.0 R spec (51,000mi) for oil change. Afterwards the shifting became harsh. Like it didn't know what gear to pick. In higher gears it felt like it slammed into gear. Big kick.
On hwy trip at time, so took to H dealership in Ohio. They input updated TCU Coding. It helped very little.
But the young Serv Advisor had overheard mechanics just weeks earlier.... If the oil is changed, and you do not put the exact filter in the canister, it can cause issues. It may fit, but it needs certain vent tubes or whatever.....
If not right, then it will trigger codes within engine..., sending bad info to TCU, and it may shift this harsh way.
I was skeptical. Home from road trip, I had oil re-changed. I mentioned issue to mechanic, he was careful to get right filter, and problem immediately dissapeared for about six mos now.
Worth a try.
That's of course why I was skeptical..@bhomer are you saying that the engine oil filter affects the shifting behavior of the transmission?
Great info, thank you for sharing.I had an issue with my 2013 3.8 where my shifts would randomly jerk. My RPMs would rise and the shift would be hard. Dealer originally said new transmission but I just lived with it until I found this TSB.
I showed the dealer the TSB, they agreed it was the likely issue, paid $650. 10k miles later it appears to have solved my issue.
