that pdf appears to have vanished
I just clicked on the link and the pdf showed up on my computer??
Should be working?
Having put up with the sorriest shifting transmission in the world I decided to look at trading my Genesis. Since I looked at M-35's when I purchased the Genesis ans I own an I-35, which has a smooth as silk shifting transmission, I started researching the M-37. In a review of the M-37 I read this:" The result is a transmission that always feels slightly confused, sometimes surprised, and rarely goes about its job subtly or unnoticed. Shifts can be jerky; downshifts are usually delayed; the wrong gear at the wrong time can be selected."
The above is a perfect summation of my transmission problems. I have decided that in an effort to increase MPG, the entire industry has screwed-up their transmissions.
I guess I'll drive the cheaper of the worst transmissions and keep the Genesis.
My transmission has started jerking when my foot lets up on the pedal like when slowing through an intersection then trying to resume speed. Not always and difficult to intentionally replicate, but at certain speeds it does happen.
So this happens when you are just driving normal OR is it when you punch it to go and then let your foot of the gas right away? I find it that if you punch it and then have to pull your foot off the gas it will jerk a little cause of the drop in RPMs.
I can't help but agree with you on automatic transmission behavior - =manufacturers set it for mpg versus immediacy, and its not something I'm a fan of.
What have you tried to remediate your transmission issues so far? Are the problems just like what you quoted above?
There are a couple other threads about transmission shifting as well. I can agree with all of you that something feels a little out of sync between gears 1 and 2. Sometimes I can find myself looking for more power and the Genesis not being the the appropriate gear.
Some people have bought a "sprint booster" and says there is a noticeable difference. Not sure how much it really helps though. I think my next purchase for the Genesis will be the sprint booster though.
mine is back in the shop again for transmission problems...I thought that the update and resetting values would have been the fix. From a dead stop you start to drive off and its like the car is building up power then BAM into 3rd almost (and it has) leaving a scratch, lurches forward big time....
Weird thing is that it will be fine for days, maybe a week then go back to acting crazy.
They tried doing the update and reset route on mine, which actually made it worse. Not to long after that I had a new transmission.
Same thing here except they never gave mine back, service rep called me and said he had authorization to replace it. I traded it in that day.
