rickkapur
2015 5.0. Turn/DRLs keep going out pretty much every year. I had the harnesses replaced two yrs ago, still the same problem. Any suggestions? Thanks
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Replace with high end LEDs like VLEDs Triton. I've put 3 years and 60,000 miles on mine with no issues.2015 5.0. Turn/DRLs keep going out pretty much every year. I had the harnesses replaced two yrs ago, still the same problem. Any suggestions? Thanks
V6 TRITON AMBER
#html-body [data-pb-style=TSUB8CO]{background-position:left top;background-size:cover;background-repeat:no-repeat;background-attachment:scroll;align-self:stretch}#html-body [data-pb-style=BJ67D5V]{background-color:#f0f0f0;padding-top:20px}#html-body [datawww.vleds.com
I never use mine either. Been 3 1/2 years since I've replaced one.Stop using them. I've never burnt a bulb in 5 years, same car. Its just a weak point.
Yes, the ones I linked are the correct ones. The Extreme are turn signal only, the regular are DRL rated and don't need a hyperflash module.Are these the one that fit? They show up as front turn bulbs. If I select DRL replacement it does not have any options. Thanks
50 SERIES HIGH VISIBILITY AMBER LED TURN SIGNAL BULBS 1157 + RESISTORS
#html-body [data-pb-style=LT68B1X]{background-position:left top;background-size:cover;background-repeat:no-repeat;background-attachment:scroll;align-self:stretch}#html-body [data-pb-style=OHJA2OO]{display:flex;width:100%}#html-body [data-pb-style=BG75HU9]www.vleds.com
Those look great - when mine burn up in a few months I'm going to order those. I wonder if I can get them without the resistor for cheaper-the ones I linked are the correct ones
Those are not DRL rated- you can ask VLEDs support, but I think they'll also consider it a warranty voidance due to thermal limits. You likely won't need a resistor as they are 10 watt lamps, but 10w is a lot of heat to dissipate for a small volume like an 1157.Those look great - when mine burn up in a few months I'm going to order those. I wonder if I can get them without the resistor for cheaper-
edit: here they are: 50 LED HIGH VISIBILITY AMBER 1157
