I, for one, don't believe the only way to have fun in a car is to hammer it. In fact, on public roads, I rarely feel the need to wack the throttle. This goes for both 4-wheels and 2-wheels. I have 3 bikes in the garage that can all do 3-sec 0-60mph, but I don't remember the last time I did anything close to that sort of nonsense.
To me, fun is to be had in the corners. Compared to straightline speed, cornering is a finesse sport and big HP/TQ is neither required nor desired. For most of my everyday driving, I take it real easy, even to the point of hypermiling just to see how high I can get the average MPG display to read. However, if I see a nice corner coming up and traffic is such that I can take it fast without causing hazard for other motorists, I'd flick into sport mode, hit the TC-OFF button, pickup a little speed if necessary so I can late brake into corner entry to load the front axle, enter the turn at just the right speed, then slice that turn hard & tight, and maybe squeeze the throttle just a bit exiting the corner just to finish it off proper. If I hit it just right, I hear a little chirp from all four A/S tires. There are few things more satisfying than nailing a nicely-executed balanced turn.
Done right, I've used very little extra fuel. If anything, maintaining momentum through the turn meant less is used to get the car back up to speed limit.
Then it ends as fast as it started. I'm back to hypermiling on the straights, listening to Diana Krall's sultry rendition of "Desperado".
