New Official 1/4 Mile Thread
New Record!
Posting this here. 1/4 mile thread has gotten pinned to the G70 forum instead of being under the subsection for "Engine" which is great. Stays at the top and will make it easy for anyone to find or ask questions.
Special congratulations to @Cashby for another awesome personal accomplishment and one for our platforms!
RankOwner1/4 TimeTrap1/8 TimeTrap60'DateDrivetrainMethodMods
1@Cashby10.79128.086.96101.931.6511/13/2022AWDDragyLAP3 Stage 2.5+ ECU tune
LAP3 TCU (stage 3+, yea its new)
BMS Charge Pipe Injection (E69)
K&N intakes
Velossa Tech Snorkels
Stock intercooler
Stock Primary downpipes
Stock Secondary downpipes
Weight Reduction: Front passenger seat out, rear seat out, removed axle back stock exhaust
Can see my blow the tires off at the start, lol...
Mods..
Tires - 245x18 Front 285x18 Rear, Nitto NT05
JB4 MAP6
ECU Tune - LAP3 Stage2.5+
TCU Tune - Lozic Pressure 4 Custom
Swaybars - SuperPro
Endlinks - SueprPro
Wheels - RPF-1 18"
Mando Suspension Controller
aFe Takeda Intakes
100% Methanol, BM10 630cc
NGT Catless Downpipes
Weight Reduction (Exhaust Dumps, Antigravity Battery, Backseats out, Passenger Seat In, No Spare Tire)
+5 Gal AEM Meth Tank (FULL)
FULL Tank of E30
Boost Launch HarnessS
Stock Snorkel Delete
Stock Intercooler
HKS Plugs 0.24
Mods..
JB4 MAP6
Swaybars - SuperPro
Endlinks - SueprPro
Wheels - RPF-1 18"
aFe Takeda Intakes
FULL Tank of E30
Stock Intercooler
HKS Plugs 0.24
Wow, pressure 4 TCU. What does that feel like??
Nice times. A better 60ft and your in the 10s!
To be honest? It feels somewhat disappointing. The shifts have a nice feel to them, but they're sluggish and take too long, I lose G's on every shift. I did a comparison of OEM TCU vs Pressure 4 60-130 and OEM was faster every single time. The Lozic TCU doesn't launch consistently, so I had to buy a harness.
I'd say it's perfect for daily driving, but if you want to set records this isn't the move.
Mods..
JB4 MAP6
Swaybars - SuperPro
Endlinks - SueprPro
Wheels - RPF-1 18"
aFe Takeda Intakes
FULL Tank of E30
Stock Intercooler
HKS Plugs 0.24
Congrats @SLEEPIN and welcome to the leaderboard!
New Entry!
2@SLEEPIN11.00126.617.12100.821.7511/17/22AWDDragyTires - 245x18 Front 285x18 Rear, Nitto NT05
JB4 MAP6
Swaybars - SuperPro
Endlinks - SueprPro
Wheels - RPF-1 18"
aFe Takeda Intakes
FULL Tank of E30
Stock Intercooler
HKS Plugs 0.24
Interesting. Have you reached out to Lozic? The shifts should be lighting fast considering how aggressive if a setting you chose.
Mods..
JB4 MAP6
Swaybars - SuperPro
Endlinks - SueprPro
Wheels - RPF-1 18"
aFe Takeda Intakes
FULL Tank of E30
Stock Intercooler
HKS Plugs 0.24
Your '18 g80 sport rwd 0 to 60 is almost as fast as my '18 g80 sport awd ;)
I had much faster times in the bank after getting it tuned, all my posted times were on jb4, but was waiting for a track day to post everything, broke my phone and lost a lot of records. It’s a shame, the G80 was a monster.
Had downpipe, meth, lap3, custom intake, custom exhaust. Currently sitting in the driveway with a blown headgasket, blown valve cover gasket and a bad starter haha.
Blown headgasket was because I was pushing 23psi to 6500rpm at 23deg of timing, I was constantly going to circuit tracks, race meets, etc. I put it through hell. LAP3 recommended less boost, I refused to send it in to be turned down.
Got down to 11.8 in the quarter, parked it and now it’s taking a well deserved break. Have some race videos still where I put a bus on a tuned m3.
I’ll be reviving it sometime next year, planning to do Hybrids on it.
New PB.
22 Awd
JB4 map 3
Bms intakes
Winter Sottozero 3 tires
1/4 tank
Congrats on the new PB! Proud to see you break into the 11's!
RankOwner1/4 Time1/4 Trap1/8 Time1/8 Trap60'DateDrivertrainMethodMods
7@Radigan11.97115.417.7091.811.822/4/2023AWDDragy22 Awd
JB4 map 3
Bms intakes
1/4 tank
2019 RWD G70 Design Edition, full weight (spare and all)
Tires: Michelin Pilot Sport 4S, stock sizes
Date: February 9th, 2023 About 8:00PM
DA: about 300ft (track at sea level, 72F temps)
Fuel: E30ish blend
Mods:
BMS Diff brace, Intercooler, Oil catch can, Intake kit, Denso 2 step Spark plug kit, JB4 (BT, FW, EWG) trans cooler
SXTH Stage 1 ECU/ Stage 2 TCU tune + JB4 custom map 6
Best time: 12.17@114.6
Fuel: E30ish blend
Mods:
Congrats and welcome to the Board!
New Entry!
8@ejguillot 12.171114.627.96190.991.9852/28/2023RWDStripBMS Diff brace, Intercooler, Oil catch can, Intake kit, Denso 2 step Spark plug kit, JB4 (BT, FW, EWG) trans cooler
SXTH Stage 1 ECU/ Stage 2 TCU tune + JB4 custom map 6, Michelin Pilot Sport 4S, stock sizes
For anyone on here chasing times, one of things to work on is manual shifting. Our cars need to be shifted before 6K rpms to stay more efficiently in the powerband.
Better yet: If you can get an accurate dyno sheet, you can calculate on a spreadsheet the best shift RPM (then adjust for the lag from pulling the paddle until shift initiated).
Formulas from Auto Math Handbook
Ideal shift RPM: Where the torque coming out of the trans to the driveshaft will be equal before and after the shift.
RPM after shift: (Ratio shifting into / ratio shifting from) x RPM before shift
Driveshaft torque: Torque at flywheel x transmission ratio.
Attached is a sample sheet I developed, with the torque numbers lifted from the Burger Tuning JB4 page for a Map 3 tune (torque numbers at RPM are a best guess from eyeballing the high res dyno sheet).
Feel free to plug in your own torque figures and see where your best shift points would be.
So in your case..
If I'm understanding this correct, it's saying the shift points are as seen in the first set of numbers?
If so, that's not going to work for fast times.
1-2: 6100
2-3: 6100
3-4: 5700
4-5: 5400-5700
5-6: 5400-5800
What's proven is more like the following.
1-2: 4800
2-3: 5000
3-4: 5300
4-5: 5600
I like the idea of this and I know this is just a sample. That being said, I have to agree with @Slip_Angle, higher horsepower cars will not get better times shifting that late. From what I understand, the first 2 shifts are what make or break your run and they need to be around the numbers 4800 and 5000 respectively. There will definitely be some variance from car to car as different tunes, weather, tires, etc come into play.
I wonder if we can work the numbers backwards to find better shift points for all power levels across the board? 🤔
Took the car out beginning of February. Still dialing it in but good to get a new baseline. This run was using 100 octane race gas instead of cpi or wmi. 11.35 @ 122.45 mph
