PagoBay
- Nov 7, 2022
- Genesis Model Year
- 2011
Hello Everyone,
Apologies for the long write up. I really hope someone can provide some helpful feedback.
I recently had an issue with my 2011 4.6 V8 sedan where the vehicle wouldn't start. All lights on dash and everything else would come on, but no start or even crank.
I tried jump starting and realized that the battery wasn't the problem and that it was most likely the Starter.
Because vehicle wasn't at home, I had it towed to the dealership which was just a couple minutes away (really didn't want to but unfortunately that was the best option at the time).
They confirmed a day later that it was the Starter. They wanted $800+ for the part alone. I got the part # from them and ordered my own replacement online for about $180.
Their labor charge was about $200 to install my supplied part, so I opted to just have them install and save myself the trouble of having the car towed home and replacing myself because it seemed like the location was a bit tricky to get to. Definitely should have been a doable job, but the math added up to me saving some time and effort by having them install.
They called me after completing the job and said that the car started up...BUT "intermittently".
They said it started up several times but had a few instances where it wouldn't. They said they wanted to check other components to make sure there wasn't some other issue. Of course, I get a call back from them saying that the ECU needs to be replaced, at a cost of $2,800 for the part alone.
According to them (dealership), the fault with the ECU is likely what burned out the old Starter. I am extremely skeptical about there actually being anything wrong with the ECU at all and was hoping I might get some helpful feedback from the community.
Has anyone with a similar vehicle had any problems or issues with the car's ECU? Has anyone had to have their ECU replaced or repaired? Has anyone had to have their Starter replaced because of an ECU failure?
My Genesis is 11 years old, and although it only has 49k miles on it, I wasn't shocked or surprised that the Starter gave out and needed replacing, based purely on age.
What I don't want to do is replace something that doesn't need to be replaced in the first place.
I'm relatively handy and do most work on my vehicles myself, with the exception of certain things that require hooking up to computer and/programming.
Any feedback would be greatly appreciated!
Happy to be a new member of the group!
