I just saw this pic this morning posted on a Kia Stinger Owners group on FB, which reminded me of this thread. Apparently this bolt has come loose, and the other bolt is gone completely. Poster said his Stinger is out-of-warranty.
For those of you not familiar, this is one of the two main bolts that secures the rear differential to the rear subframe. These mounts were designed to hold the differential in place and NOT to support the weight of the entire rear end of the car. Those rubber bushings were precisely tuned to help isolate the movement of the rear diff from the subframe, reducing noise transmitted into the cabin and dampen the shock & vibration sustained by the differential when the full torque of the 3.3T engine is applied. Last thing I want is to drop the weight of the car on those bushings and risk near-certain damage to their structural integrity. You might not "see" any problem right away, but whatever is done will come back to bite you in the rear end (pun intended) sooner or later.
Here is a view of those bushings on my Stinger: Notice the factory bolt alignment marks (yellow grease pencil drawn) are off, because I actually R&R the original open diff with an LSD from a donor G70 6MT I found on ebay.
I actually used my 3rd jack to raise & lower the diff for removal and installation.
My experience tells me 3 things:
1. The versatility and utility of having a 3rd floor jack is invaluable.
2. Said jack should only be used to support the weight of the differential (plus drive shafts) and not much else.
3. You would have to be an utter moron to think it a good idea to jack up the whole rear end of the car on the rear diff.
For reference, here is a clearer view of mounting points on the diffs. Right one is currently in my Stinger.
