Harbor Freight to the rescue once again............
MADDMOE
NY NY
.....decided to use my harbor freight 2 ton press and do these myself, thats just the front drivers side, ill get to the passenger side tomorrow......
Good work. Which bushings are those? Where did you by replacements from?
.....the seller is FASTAUTOSUPPLY on eBay, they had em all for my 4.6 V8.......
.....and this is why I started this bushing replacement , these are from the front passenger side......drivers side is done and back together.........tomorrow I'll press these bushings out and hopefully have my car back on the ground by Wednesday and go get a wheel alignment......
.....well passenger side is done, time to put this car back together and go get my wheel alignment and fine the time to wash & wax it........
What was the sign of these being worn prior to taking it all apart? I'm getting a clunking noise in my driver's side front suspension.
.......I knew I needed a wheel alignment , the construction caused by Con Ed replacing all the gas lines tore up all the streets around me tearing up cars suspensions I'm sure.........but my intention wasn't to do this , I was only going to do my fluids ( transmission, oil, coolant & brake fluids changed ) but once I took my wheels off to also do a tire rotation I took a flashlight and could see the cracks in the bushings very clearly......now I replaced my front control arms before (upper & lowers) but this time I wanted to use my harbor freight machine because I'm retired and had nothing better else to do, I guess lol........and I'm just getting back from getting a wheel alignment and it feels so much better, so much.....I would suggest you take off that wheel and get a flashlight and look at all the bushings, you will see if they are cracked or not
