New System and MAP update v17.0 coming in May!
They added this recently so looks like it will be early May!Screenshot_20230410_104619_Samsung Internet.webp
Worked PERFECTLY!! Now have the full screen AA maps and updated audio features!
Thanks for the input and help.
Happy G70 owner here... :)
Hey I just used the updater and USB drive to update my '23 G70 3.3T. Was there something you had to do to get full screen AA to work? Mine still looks the same as prior to the update... Thank you in advance for the help!
I did the update and the AA map became full screen. Didn't have to do anything extra.
Thanks for the quick reply. I found that I had to go into Settings > device connections > phone projection and deselect the split screen option for it to work. It's great now! Thanks again!
Sorry if it's been mentioned before but I just noticed there's a Display Audio Gen 1 update for 2019-2020 G70s. Looks like it was released on 4/14/23. I'm going to install it tomorrow.
I could be wrong but I believe that's for models without navigation.
  • Like
Reactions: Mcc
Are there any models without navigation?
There must be since the FAQs on the website where you can order the update states that non-navigation models use that update.
Not sure. The owner's site recommended it for my vehicle and I have nav. I've never seen a Genesis without navigation but I could be wrong. Maybe I'll wait before I screw something up.
See attached
But the update I posted about is for "Better remote access with seamless connectivity between the Display Audio System and the Genesis Connected Services server."
It doesn't reference Apple Car Play / Android Auto. Anyway, someone will end up installing either one and report what it fixed/broke...
Correct. The way I read it, the Display Audio update should make non-nav models communicate better with Genesis Connected Services. If you have a nav model, you should use the regular update, which will update your maps and the system. Of course, I could be wrong. The only real way to find out would be to contact Genesis.
From the update list doesn't seem like much is new if you don't have an EV? Unless some changes aren't listed
I realize that Genesis does do small updates to the UI and audio system, etc with the MAP updates, but I really only download it to update my Map lol.
I don't particularly care about the changelog myself.
Getting the latest and greatest. Even if it's minor changes.
Unless it has changed, they are free to order for at least the three years. Just select bill to Genesis at the end of the order process.
I'm new to genesis so sorry for the dumb question. But where do you go to order the cable and get the updates? Thank you in advance.
When you say cable, do you really mean USB stick?
Are you asking about getting the update mailed to you (at no charge) already on a USB stick?
Are are you asking about downloading the update to a USB stick that you already have?
You really should set up an account on the Genesis Owner's site, as it explains all this and more.
There are some kind people on this forum explaining things like this.
Sometimes it is good as well to know your limits and update through the dealer.
