The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Hey I just used the updater and USB drive to update my '23 G70 3.3T. Was there something you had to do to get full screen AA to work? Mine still looks the same as prior to the update... Thank you in advance for the help!Worked PERFECTLY!! Now have the full screen AA maps and updated audio features!
Thanks for the input and help.
Happy G70 owner here...![]()
I did the update and the AA map became full screen. Didn't have to do anything extra.Hey I just used the updater and USB drive to update my '23 G70 3.3T. Was there something you had to do to get full screen AA to work? Mine still looks the same as prior to the update... Thank you in advance for the help!
Thanks for the quick reply. I found that I had to go into Settings > device connections > phone projection and deselect the split screen option for it to work. It's great now! Thanks again!I did the update and the AA map became full screen. Didn't have to do anything extra.
I could be wrong but I believe that's for models without navigation.Sorry if it's been mentioned before but I just noticed there's a Display Audio Gen 1 update for 2019-2020 G70s. Looks like it was released on 4/14/23. I'm going to install it tomorrow.
Are there any models without navigation?I could be wrong but I believe that's for models without navigation.
There must be since the FAQs on the website where you can order the update states that non-navigation models use that update.Are there any models without navigation?
Not sure. The owner's site recommended it for my vehicle and I have nav. I've never seen a Genesis without navigation but I could be wrong. Maybe I'll wait before I screw something up.There must be since the FAQs on the website where you can order the update states that non-navigation models use that update.
See attachedNot sure. The owner's site recommended it for my vehicle and I have nav. I've never seen a Genesis without navigation but I could be wrong. Maybe I'll wait before I screw something up.
But the update I posted about is for "Better remote access with seamless connectivity between the Display Audio System and the Genesis Connected Services server."See attached
Correct. The way I read it, the Display Audio update should make non-nav models communicate better with Genesis Connected Services. If you have a nav model, you should use the regular update, which will update your maps and the system. Of course, I could be wrong. The only real way to find out would be to contact Genesis.But the update I posted about is for "Better remote access with seamless connectivity between the Display Audio System and the Genesis Connected Services server."
It doesn't reference Apple Car Play / Android Auto. Anyway, someone will end up installing either one and report what it fixed/broke...
Nicee! Thanks for sharing !New Genesis Map update available for download now: Notice | Official Genesis Navigation Update Website
From the update list doesn't seem like much is new if you don't have an EV? Unless some changes aren't listed
I'm new to genesis so sorry for the dumb question. But where do you go to order the cable and get the updates? Thank you in advance.Unless it has changed, they are free to order for at least the three years. Just select bill to Genesis at the end of the order process.
When you say cable, do you really mean USB stick?I'm new to genesis so sorry for the dumb question. But where do you go to order the cable and get the updates? Thank you in advance.
