And also good to extend your limits, or you'd never learn anything newSometimes it is good as well to know your limits and update through the dealer.
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Time on the camera view is from an older update, not this latest one.I updated mine over the air as I was driving yesterday. Only took about 20 minutes in all.
So far
The good: they added the time to the camera view.
The bad (mostly annoying really): I lost 3 present stations and for some reason XM channel 0 was added to my presets.
I haven't noticed anything else yet.
No need to leave it on accessory mode. It turns off automatically after exactly 1 hour anyway, which is not enough for the 1.5 hours needed for this latest update. I haven't done it on the G70 yet, because the update was pulled. But did it on the '22 SF Calligraphy, and took 1-1/2 hours. Geez. Will have to redo it on the SF, since it has a bug somewhere. Oh well.
perhaps I got lucky this time but 2 weeks ago my update to HD then to USB then to car worked fine.Did update successfully with USB drive today on GV70(2023). Things to note (as others have said) .
1. Do not download update to your hard drive and then copy to USB - it will not work. You need to download the files directly to the USB drive.
2. Once in car and you've plugged into the USB port (I used same port that I plug iPhone in for Carplay) - then go to settings/general/ SW info and the Update button should be available to click.
3. After I clicked Update, the update started and showed a progress bar (it stays at 0% for a few minutes so don't panic). I let that go to about 10% with car running. I then hit Start/Stop buttong to stop the engine and then pushed Start/Stop button again (without stepping on brake) to put the car in Accessory mode. I then left the car (took my keys with me) and let it sit for about an hour. When you put car into Accessory mode, make sure you turn of your headlights using the switch on left side of steering wheel if you have them on AUTO - otherwise they will stay on for the hour.
3. I did not have to take any additional steps. When I cam back to the car everything was off (was no longer in accessory mode - so I am not sure if you even need to put car in accessory mode in the first place, but that's what I did). I started the care and the update was complete. You can confirm by going to the settings/general/update screen again and you should see the new date that you updated the software.
4. Return your lights to AUTO.
To clarify, I reported this. The issues is that on unmarked rural roads in Michigan, the default speed limit is 55 Mph. In those areas, the nav system always reported the correct speed. Live of one of the roads, btw. Now it always reports 25 Mph, and it's not just the road I live off of, but all the rural roads I drive on.The revised update for 22-23 G70s is NOT available yet (just checked again). And one bug reported was a speed limit of 25 mph on all streets. Maybe it's the only one, or maybe not; who knows. But it's taking more than it should. Hopefully we can download it again soon; we'll see.
Here it now reports 25 MPH for all the roads that it did not display a speed limit for before. Some of them are actually 20, most are actually 35 or 45, and some are more. Roads that it had speed limits for before are still correct.... Now it always reports 25 Mph, and it's not just the road I live off of, but all the rural roads I drive on.
