Random question, but how do I disable the backup camera?
Genesiswonderer
Don’t ask why, but I’m wondering. Have the standard 8 inch head unit. I see three options to do this.
1: in the engineering menu I found an option to turn it off but I’m afraid using this will mess up the software.
2: I could pull the fuse for the camera but in this case I’m afraid that if I want to turn it back on it will have to be reprogrammed or something
3: I could put a piece of tape over the camera
Thoughts?
Thoughts?
#3 Easily reversed too. Won't ask why, but could not live withut it these days.
I would just wait. The wire to the backup camera will break soon enough.
How expensive is that to fix once it happens? Isn’t it the trunk wiring harness or something that’s a common failure on these cars
Yes, it is a common failure. In my case the dealer ran a separate signal wire from the trunk to the head unit. A couple of years later, something else failed and I've not had a functioning camera for about 6 months. It could be the ground or it could be a connector at the camera?
As far as expense, I don't know. Probably at least a few hundred dollars.
Other people have been able to do the TSB themselves and find the breaks in the wires where the harness bends. I have not been able to find the break so far. Additionally, the trunk switch wires will often fail as well; I haven't been able to fix that either.
fixed that for you
Thousands to replace the harness, but only a few hundred to repair the existing harness as is recommended. You can do it yourself for tens of dollars in parts.
Okay. Will it help prolong the life of the harness if I refrain from opening and closing the trunk and opening and closing the trunk as little as possible?
Just as much (not all) of the car will last longer if you refrain from driving it more than once a week.
Did you buy it to use it or to keep it?
