Diagnostic Code Checker and Reset
Maybaum
Genesis G90
I am seeking recommendations for a diagnostic code checker. Can I use an off-the-shelf tester, or is there a recommended tester for my 2020 G90? For instance, this one from Amazon:
the one you have selected should work fine. to my knowledge any odb2 scanner should work.
Here's one that has been recommended by Scotty Kilmer on YT:
Video:
Thank you. I went on YouTube and watched this video and ended up ordering the plug-in with blue tooth to my smartphone from Amazon. Appreciate the tip.
I use an elm327 and torque lite. eBay has the elm327 for $2.64 and torque lite is free at play store. With a smart phone you can see the dts and do a reset. There are many other apps you can use for free. For most problems it will be all you need.
Thank you, will check it out.
