onecrappie
- Mar 6, 2023
- Genesis Model Year
- 2021
- Genesis G70
A small, easy DIY mod from Burger Motorsports for unlimited burnouts or a boosted launch. Others may have posted about it before but I'm too lazy to search. This mod originally involved cutting the black/green wire going to the ECU and installing a switch. When turned off, it allows you to build boost while your foot is on the brake. Someone else found that you can use a fuse Socket Connector and switch to turn off that fuse. No wire cutting involved and you can mount inside the cabin.
Original Post
I wanted something fancier and found a switch I liked better. Buy it here. They have multiple metal colors and led combinations. Just make sure it is NC, ON-OFF, and 12VDC.
Here is the wiring:
And finished product
You'll need a ground unlike a regular switch.
Here is a video in action. It does turn off traction control.
Original Post
Here is the wiring:
