What have you done to your GV60 today?
Looking to make your GV60 unique? Look no further than KDM Warehouse - where orders are shipped immediately!
Yeah I'll chance it I think... other tire is at 7.5/32" or so, so 2.5/32" difference
Yeah you should be absolutely fine. Its funny how the standard changes depending on who is paying for the tires. If the dealer or warranty is paying I have heard them claim as much as 6/32 difference is acceptable but if its on your dime they will tell you 2/32 is the max, crazy.
Installed the Dynamic floating wheel caps today. Always liked those things on my other cars. You can see by the pictures they are a much more robust cap. Also they stick out from the hub a little, so they look like they could be stolen easier. But the strength of the spring holding them in, I tried, and I couldn't pull them out by hand.
View attachment 58487View attachment 58488
Did you buy them from KDM. Their website says they fit 19" and 20" wheels. I wrote to them and asked if they have ones that would fit the GV60 21" wheels and they said no. It looks like you also have 21" wheels.
Just installed The Ioniq Guy's walk-away automatic door lock device for GV60. Works like a charm! Easy to install through the trailer hitch light wiring harness, and I'm pleased that it's possible to disable the device using the keyfob before any dealer maintenance (and then re-enable afterward).
A MagSafe iPhone mount, placed in the empty space between the two screens. It can be connected to USB power to serve as a wireless charger, but until the update enabling wireless CarPlay, it’s just a mount as I connect the phone via USB.
I don’t know why I waited so long to do this.
I bought this mount specifically for the GV60. It was quite expensive (about $90) but I'm very happy with it. It's super solid, and put's the phone in a perfect position both out of the way and readily to hand, and it looks like it's OEM.
Angled Dash Mount for Genesis GV60
The Genesis GV60 Angled Dash Mount is made specifically for your vehicle starting from 2023 (See below for full list of compatibility). This mount attaches over the center vent. Combine with a ProClip device holder to make a complete mounting solution for your phone or GPS. The ProClip mount...
www.proclipusa.com
www.proclipusa.com
I also got this coiled USB-C to lightning cable. So far it's held up well. There is also a USB-C to USB-C version.
Amazon.com
www.proclipusa.com
www.proclipusa.com
Amazon.com
Proclip makes the very best mounts. Worth the cost imo.
Can the vent still move with the mount in place?
Yes, it doesn't even touch the vent.
Before I got the ProClip mount I had a vent mount that worked pretty well in the same spot. But of course that did prevent the vent from moving, and also would occasionally fall out. I was really concerned that eventually it would damage the vent. Absolutely no concern with the ProClip mount. The position of the phone is also perfect for the occasional times when I do need to look at the phone itself, for example on road trips I keep ABRP running on the phone while using Apple Maps for the actual navigation. I've got an OBD port so ABRP shows the estimated SOC at the next charger, I just watch that on the phone itself. I prefer Apple Maps for navigation because it tells me what lane to get into, etc. Also I find ABRP a bit glitchy in CarPlay.
Starting using Proclip when they first started out. Great products.
Does this work with DK2 (phone)? Could not find it listed on the website. Would be nice if the spring (fall) update enabled this feature. It does auto-lock when approaching the vehicle if you do not open the vehicle, but only under those conditions
I have an Advanced, so I don't know for sure about Digital Key 2.
However, I have tested my device successfully after a Face Connect unlock.
Installed last week don't know why I waited so long. I think as far as upgrades this was the best one.
Any update on this @GreyGV60? I also have the 21" wheels and was told no by KDM. Can you please share where you purchased them from?
Just added it also. It's curious that Genesis enabled Unlock-on-approach but not Lock-on-out-of-range.
