Cheapest G70 Exhaust Actually Sounds Good?
TheBeginning
Expert Tuner
As many of you now, the G70 and stinger share a ton of mechanical components. This is great because G70 owners, like myself, have access to a wealth of aftermarket parts driven primarily by demand from the Stinger community. However, due to the shorter wheelbase Stinger exhausts do not fit the G70. Aside from a fully custom exhaust, there aren’t many options for the Genesis, and they all caused around $3000. The pre-facelift G70 factory exhaust is definitely sport tuned, but leaves something to be desired for us enthusiasts. I’m coming from a 2015 Genesis Sedan 5.0 which I installed valved cutouts on just before the muffler. That Tau V8 was so easy to make sound good, but the Lambda II V6 takes a lot more effort. I was considering the ARK GRiP since it does some black magic to the exhaust gas and sounds the best. Between the price and loudness, I opted for a valved system over the ARK. Only problem, these are still $3000, more than I’m willing to spend. I remember seeing videos showing where valvetr0nic gets their exhausts and decided to try there (Alibaba). With no other options I decided to take a chance, Columbus did. There were a few listings for G70 exhausts, but they all looked identical. Went with the ING brand linked here.
After ordering the exhaust they kept me posted on the build status and shipping. I purchased the expedited shipping and the product arrived in about a month. It came with the resonated mid pipe, valved muffler sections, electronic valves, controller, module, remote, wiring (power wire and connector for each valve), and hardware (4x gaskets, 10x bolt, nut and washers).
So far I just put on the muffler section and it exceeds my expectations. Check out the sound clips.
Video
It’s a valved exhaust which uses electronic butterfly valves to either send exhaust through a muffler or bypass it. With the valves closed it’s a bit quieter than stock when cruising around and no drone. With the valves open, exhaust bypasses the muffler turning up the volume. This system has a small resonator which cleans up the sound when the valves are open, I circled in red in one of the pictures. The one downside is how restrictive it is with valves closed. You can hear a loud whooshing noise if you get above 4000 rpm with the valves closed. I attribute it to small leakage through the valve, sharp angle between muffler/main pipe, and a more restrictive muffler.
Compared to my previous valves, the remote is way nicer. Outside ring is metal, which gives it a nice hand feel, and the design looks sharp. Kinda looks familiar, doesn’t it?
For anyone looking to purchase this exhaust see the contacts below. I am not sponsored or affiliated in any way, I just had a good experience and want to provide my source for anyone who wants to do the same. No gatekeeping.
Product Listing:
https://m.alibaba.com/x/AxjBZ4?ck=pdp
Company Instagram:
https://www.instagram.com/ing_exhaust?igsh=cjRxcjg0ejF2emp6
I worked with Danna whose number is +8618923037350 in WhatsApp.
What was the total price to your door, and anything damaged during shipping??
Great writeup, I like it!
Thanks! I was surprised no one has gotten this or posted about it. Always nice to hear other’s experiences, so I’m detailing mine. I’ll follow up once I get mid-pipe in.
Nothing damaged. Parts were protected really well with bubble wrap and shrink wrap. The boxes were a bit banged up, but nothing happened to parts. Here’s my cost breakdown;
Product price: $694.00
Shipping: $347.00 (faster option, cheapest was ~$150)
Tax: $66.10
Total: $1107.10
How did you (or what video did you use) to wire it up? Sounds great!
Any issues with drone?
Not at all. With the valves closed it’s quieter than stock. With the valves open it acts like a muffler delete and would drone, but I just close them if I’m cruising. Has a remote which closes the valves in a second, so it’s easy to switch back and forth.
Used a fuse tap into the fuse box under the trunk (with the battery). That powers the controller module which I left near the battery. Ran wires from there, through a hole in the floor, out to the valves. Relatively simple. Hardest part is the fuse tap.
@TheBeginning curious how you did the fuse tap near the battery? I installed this exhaust but haven't hooked up the valves yet. I noticed there is just 1 micro 10amp fuse in the box on the battery. Is that all you used to power the module box or something else?
Where abouts do the tips sit? I tried asking the people on alibaba and they weren't much help. Im wanting to do a quad tip setup...
