October Manual Update Newer than Recent OTA Update
Does anyone have a link to a manual update file for the GV60 for the Korean market? My car is from Korea and is now in Kazakhstan, but the program does not allow those who are not in Korea to download an update for a Korean car
Through the VPN service, I was able to download the update files for the GV60 for the Korean market. For some reason, its size is only 14 GB. But I was unable to update the machine. I insert a flash card and nothing happens
In my Advanced model, after the update, I see the brake lights go on when I'm in Auto regen level 3, but if I just put on the brakes with no regen, put the car in level 0, I don't see the brake lights when I apply them. Very strange. Hopefully my brake lights are working.
Level 0 isn't really a "level". According to the Manual, it's a "Clean Mode" for your brakes and once you set it to Level 0, it will automatically change back once cleaning is finished.
Now... WHAT IS CLEANING you might ask?!!? The best I can come up with is that because we're not really using any brakes (when using Regen), the pads oxidize from moisture and will squeal from that when you eventually use them. The Level 0 cleaning mode is probably a way to turn off Regen so you need to use the brakes, which subsequently will knock off the oxidation. Not really any cleaning going on... but, by nature of you actually using the brakes... I guess the outcome is the same.
Level 0 isn’t a cleaning mode, it’s zero regen… As a result you will NEED to use your brakes, as there is no regen braking, so the car will run a pad clean as they have possibly not been used for a long time. It’s a safety thing.
That note is warning you the paddles will not work when the pads are mid way through that clean cycle in level-0 regen mode.
Hence the start of the section reads: “The paddle shifter does not operate when:”
Which USB slot do you need to use to do the updates?
The one that says USB vs an electric lightning bolt, which is charge only….
In the front, on the left, the same port used for Android Auto/Apple CarPlay….
I’m updating at the moment and it is taking a lot of time.
Does this update break anything? Scared it'll do what hyundai did to eco mode on the ioniq 5s that updated to get battery preconditioning. Any other note worthy changes other than the ones listed in this post?
Tried to update using a usb driver and it gets to 100% then tells me the update did not work possibly due to “a corrupted file”
I deleted the update and redownloaded and tried again but still no success.
Any recommendations?
Same thing just happened to me. Did you ever get this resolved?
Nope! I haven’t tried again since. Let me know if you figure it out!
A couple of new changes I noticed since yesterday:
The tailight in the display now lights up when the brakes are applied. Interestingly the horizontal light bar doesn't light up. Strange miss of a detail, but better than nothing.
There's now an option to choose general brake characteristics between "Comfort" or "Sport."
Now you can set the ESC to be entirely disabled in My Drive Mode.
Its March and I finally did this update and was most looking forward to the regen brake light indicator. However, since I updated, my screen is different and I no longer see the car icon. I see Nav, which I don't want there. I looked and couldn't figure out how to change it back. Any idea what menu that is under?
The centre portion of the screen is selected using the ‘layers’ toggle on the steering wheel. Right-most toggle on the left side of wheel.
Yes, more than a month ago. Got the second update also.
Hmm that’s odd! Any reason why I may not have gotten it?
Would I be able to manually update it?
If I were driving in regen mode 3 for example but I wanted to clean my brakes/rotors and switched the mode to "0", then I should leave it in "0" to clean and then it will automatically go back to my original setting of regen mode 3 when the brake/rotor cleaning process is completed? How long does the process normally take?
