Do basic OBD2 scanners work on 2022/23 G70s?
Impressive! Have you used it yet to change anything? Anything interesting that you have discovered?
I see there are a few versions of the XTOOL - D7, D7S, D8S, D9S.. Is the one you have the D8S? It's $719CDN on Amazon.
Hi yes it’s D8s but you can get it cheaper from china but that’s upto the buyer.
I haven’t played around with it yet as I got sudden issue with my back, I will update if it can do change anything but me personally I bought it for diagnostic purposes and to use the special functions
Assuming you had time to play with it… can you change the suspension variant coding?
I did look at it. My model doesn't have the programming feature so sadly no. (I was really hoping it did). I can see it, just can't change it...
"I know this post is old, but I’ve done some serious digging into OBD2 scanners and landed on the YOUCANIC Full System Scanner. Why? It’s a total game-changer! It doesn’t just check the basics like engine, ABS, or airbags—it covers everything, including ADAS. Bonus points: it does active tests, requires zero subscriptions (yes, free for life), and the U.S.-based support team is 🔥. Oh, and it works on all car makes and is ridiculously easy to use.
Can it do variant coding?
Which version is it as they do quite a few ?
I presume it’s the
YOUCANIC Pro UCAN-II-B​
I had a Quick Look and noticed it doesn’t have as much features as mine, I never looked at everything but I looked for example instrument cluster, mine can do variant coding but the one you mentioned can’t do it . This is a huge problem with free lifetime update diagnostic tools, they don’t do as much updates and things are missing compared to other ones. So I don’t think it’s a game changer.
Edit: also no key programming option for any vehicle, mine can’t do Genesis as far as I know but can do some vehicles
I'm looking at the launch x431 pro elite. It looks like it may be able to do variant coding changes.. if anyone has any experience with it on our cars, please let me know!
What ty
What type of variant coding you want to do ?
I hooked my Launch X431 Pro to my 2019 G80 and found no available coding options that weren’t already available in the car’s dashboard menus. The Launch can do maintenance items like resetting oil change reminders, programming TPMS sensors, etc., and I was able to program the car for a new key fob, but the car is locked down pretty tight as far as coding goes.
According to the launch vehicle coverage, the G80 does have support though it seems more limited then the G70.
G70 Suspension coding
Well I stand corrected. My Launch X431+ Pro gives these options for ECS variant coding.
Ok, sweet. So what are the options? Can you change it to Europe/Asia?
It took me awhile to resize the photo and get it attached but it now shows the options.
Nice. I hear Europe for the G70 is excellent - much better suspension settings for comfort and sport. Do you plan to try changing it to another region?
I might try it but I doubt my backside would be able to tell a difference.
