Anyone else have issues with interior rattles?
I took my GV70 to the dealership today. They said they’re going to keep it overnight so they can take it on multiple test drives tomorrow to replicate the rattles. My loaner is an electric GV70 with more miles than my personal GV70, and it is rattle free. Definitely just a me issue with my particular vehicle.
This is an older thread, but I thought I'd add to it.
I have a '23 Electrified GV70 and the interior has been rattle-free until recently. Lately I've noticed that when driving on bumpy/rougher roads there is a "rattle" sound coming from the front passenger door. I've discovered that when the rattle is happening, if I lean way over and press against the armrest/mood lighting area of the front passenger door the rattle goes away immediately. When I remove my hand the rattles comes right back.
This weekend I intend to remove the front passenger door's trim panel and give it a thorough inspection, looking for anything loose that would cause a rattle sound. Before remounting the panel I'm going to apply some self-adhesive 1/2" wide 1/8" thick seal foam tape around the perimeter of the metal door frame where the trim panel attaches against. The foam tape should add a small amount of added isolation from vehicle vibration while also putting some additional "load" on the numerous trim panel-to-door frame snap fasteners, one or more of which may also be rattling at times. After I'm done I will update this thread with my results.
/rb
/rb
Further to my previous post, I succeeded in eliminating the rattle sound from my front passenger door by following the procedure I outlined. I didn't have any luck at first removing the passenger door trim panel using conventional trim tools, and I became concerned that I might damage the panel if I pried too hard. I then searched for other methods online and came across an interesting video. I discovered that the best/safest way to pop off a door panel is by using an air pump wedge bag tool. It cost me $10 for the 'tool' and I had the door panel off in less than 2 minutes, with no drama. After applying the foam tape and reapplying the door panel, the rattle sound is completely gone now. I'm very pleased with the result. :)
I have a rattling/ vibrating noise coming somewhere from the rear hatch. Took it it three times already and it’s still making noise
Me too...the weird part is it is bad when I start driving but gets better after a few minutes...not gone but better. Can't figure that one out.
Thanks for the follow up status. My '25 has the same exact rattle on the passenger door as did my '23, so I'm going to try this remedy since the dealer doesn't seem to be able to fix it.
^ Sounds good damosis. Let me know if you have any questions about the procedure prior to or during the job.
As info, I bought the 1/2 inch wide x 1/8 inch thick self-adhesive foam tape on Amazon.ca. Here's the link to the listing:
In buying 50 feet of the stuff I had plenty of foam tape left over! 🤣
Before you buy anything or start the job, I suggest you make doubly certain the rattle is coming from the front passenger door panel and not from something like the front passenger seat headrest (which can sometimes be the bad actor, especially when a passenger isn't sitting in the seat).
I've attached a photo below of my front passenger door with the inner panel removed and the foam tape applied around much of the door frame where the outer perimeter of the inner panel meets with the door frame. Prior to removing the inner panel I ran some painter's tape around the door frame (following the perimeter edge of the inner panel) to serve as a border/template for where to place the foam tape. My reasoning was that I didn't want to see any foam tape showing after the inner panel was re-applied.
Good luck with the 'project' and Happy New Year!
Richard
As info, I bought the 1/2 inch wide x 1/2 inch thick self-adhesive foam tape on Amazon.ca. Here's the link to the listing:
Buying 50 feet of the stuff I had plenty of foam tape left over! 🤣
I've attached a photo below of my front passenger door with the inner panel removed and the foam tape applied around much of the door frame where the outer perimeter of the inner panel meets with the door frame. Prior to removing the inner panel I ran some painter's tape around the door frame (following the perimeter edge of the inner panel) to serve as a border/template for where to place the foam tape. My reasoning was I didn't want to see any foam tape showing at all once the inner panel was re-applied.
Richard
Great detail, that helps a lot, thank you ! I'm certain it's the panel, in both cars if I push where the red circle is, the noise goes away and comes right back when pressure is relieved.
^ You're welcome. 👍 Based on the location of where the noise goes away when pressure is applied on your front passenger door panel, I would recommend you apply foam tape in that area of the door frame as well. I didn't apply any foam tape along the top part of the door frame (below the window glass) in my car, but in retrospect I probably should have. Luckily I eliminated my rattle/noise issue without doing that.
I got my car yesterday and seems like there is an annoying clicking noise coking from back, i have chicked the back chairs and fixed the posture and folded them as many mentioned in the form .... but still, the sound is there and its more at nighttime (maybe duo to temp) i have even checked the back and fixed and tightened everything with the spare wheel .
I had this nightmare for 9 years with my 2016 maxima and seems like im doing it all over again since dealers knows shit usually 😐
