Setup button, then two screens to the right, I believe it's labeled GeneralWhere in the car's infotainment do I go to start/access this update?
The infotainment screen should prompt you right away to update once the USB drive is inserted. If it doesn’t, there might be an incompatibility with the drive or a bad download.Where in the car's infotainment do I go to start/access this update?
Not at all. Is your USB on the correct slot, below the HVAC controls on the left hand slot. Second, did you use the Genesis Updater to actually write to the USB drive?Thank you - found it, and it shows that an OTA update is available, but the "Update" button is grayed out.
Poked around, couldn't figure out why....
Is a USB drive a requirement for performing even the OTA update?
Maybe it is worth waiting for the OTA? No, as far as I'm aware, you do not get a thumb drive with the car. You would have needed to buy. I believe they require at least a 64gig thumb drive, must be USB-C of course. The Genesis Updater will format the thumb drive as ExFat and put the Update files on it, such that you pretty much just have to turn the car on and plug the USB thumb drive in.I think my ignorance of how this all works is causing my issues. We have never had any USB drive inserted in either of the USB slots below the dash - only USB cables to use wired CarPlay (left) and to charge a phone (right). Were we supposed to get a drive or card with the car, or is that something we'd have needed to buy?
I’ve had the same experience. I have one particular USB-C drive that works perfectly in various devices, but the GV60 won’t recognize it at all. And yes, I’ve tried various formatting options.The GV60 seems to be very picky about USB drives, despite having been successful in the past.
I have had the same experience. It’s not picky about the drive capacity either as I’ve successfully used various capacities ranging from 64Gb to 1Tb. I’m not sure why it doesn’t like certain drives.I’ve had the same experience. I have one particular USB-C drive that works perfectly in various devices, but the GV60 won’t recognize it at all. And yes, I’ve tried various formatting options.
it worked fine for me on the first attempt.Has anyone in Canada had luck applying this update? I've done several downloads on 3 different USB drives with no luck. The GV60 reads the USB drive but doesn't seem to recognize that it needs to kick off an update.
similar story here:I downloaded the file yesterday, but when I went out to the car to install, the OTA update was already at the 80% point, so I just let it finish.
what did it update?..Mine automatically updated last evening when I shut the car off.
