Rough idle while in drive but not in park - 2012 3.8
joe2553
Charleston, SC
Noticed the other day that the car has a noticably rougher idle while in drive but not while in park. I'm taking it to the shop for new tires and breaks tomorrow, any suggestions for potential issues they could check while they have the car? Thanks in advance!
Also is there any other general maintenance I should have them look out for? The car has 88k miles, I was going to have them check the spark plugs, should I have the brake/transmission fluids flushed as well?
This reminds me of a TPS issue, throttle position sensor. I had this once with my wife's 2001 Durango in 2007.
My 2014 was still under warranty at 88K (2017) miles so I did the transmission drain and service (no flush capabilities that I am aware of) and also the differential drain and service. I am probably overdue right now at 236,800 miles but I have purchased a new transmission pan/filter combination with new hardware a while ago. Unfortunately, some work needs, grandchildren and parent and in-law medical needs and care have taken priority. Use good fuel and Techron (I learned this from the Genesis "Guru's" here on the forum). My oil gets changed every 3-4K miles with semi-synthetic oil since knew and I only use Wix filters.
Same problem for me , i had a p0017 came and After replacing both oil control valves as well as the crankshaft position sensor, we’re now thinking the issue might be with the CVVTs. So I’ll probably have to replace the timing chain.
If you figure out the problem before I do, please let me know!
