Power trunk
pgermain
Has anyone had problems with their power trunk on the Genesis G70 2020
What problems are you having?
On my G80, I was getting trunk ajar warnings when it was closed. Adjusting the bump-stops resolved that. Recently, it would sometime reclose after it opened about a foot. I fixed that by replacing the trunk lid air struts.
The power trunk only opens halfway, and then most of the time only closes halfway. They changed the struts already.
Assuming the initialization procedure is the same...
Slowly push the trunk lid to the fully open position.
Press and hold the outer trunk open switch at the same time as the close switch on the inside of the trunk lid.
After about three seconds a warning will sound. Release both switches at the same time.
Slowly push the trunk lid closed all the way.
Press the outside open switch.
The trunk should open all the way and a warning sound. Initialization should be complete.
Maybe this will help.
I went on a 6+ month adventure with the power trunk on my 2020. I had a similar issue as described. The trunk would open anywhere from 6 inches to halfway. Warning beep and lights would flash. Multiple presses of the open button would cause the trunk to open a little more until it was completely opened. Closing was smooth and never halted.
I replaced the fuse in the trunk. Dealer first replaced the latch, then the opening motor. None of these fixes helped. The issue turned out to be a stressed wire that likely started to fail due to the number of times the trunk was opened (multiple times each day). I was told there were other Kia/Hyundai products experiencing a similar issue, but no Genesis vehicles were part of the impacted list at that time.
After the fixed was the trunk working properly and again, thanks for the info
The dealer has been working on my car on and off since 2024 still not fixed!!!
