G70 BMS 450HP kit.. Catless Downpipes or High Flow Cats?
Tombugg
So Installed the BMS 450HP kit now deciding between the ***-less down pipes or High flow cats.. I live in FL so don't have to worry about smog. Was curious about what HP gains I could expect with either set up and if I do go ***-less will I need to do anything with the tune to not throw CEL?
Cons / Benefits of each for anyone that has done it?
Sorry if this is already posted, I googled, checked the JB4 forum and looked through here. If it is apologies, can someone point me to it?
As always, thanks in advance!
Tom
Go catless. Since you're in Florida, you don't need the high-flow cats.
You'll get a bit more power and sound without them. The high-flow cats are really just for emissions legality.
Yes, you will get a check engine light with catless downpipes. Your JB4 can likely clear the code for you, or you'll need a separate O2 sensor spacer to prevent it.
Tom
You will need a BEF to run catless primaries. You can run catless secondaries though.
