ctrcbob
CTRC, USN Ret.
- Jan 11, 2009
- Genesis G80
Hey Bob, you live in Roswell? I grew up there! I live in North Carolina now, but my wife and I were there for one night last summer. You may recognize this place:
And the instructions on how to check the fluid level are attached at the bottom of this post. Draining the fluid is pretty obvious, you just unscrew the plug and let the fluid drain out. To refill it, you reinsert the drain plug (obviously) and then unscrew the fill plug, which is on the right side of the transmission towards the back. The fill hole is surprisingly low, and that's why the engine has to be running when you fill the transmission. With the engine running and the transmission in gear the fluid is sucked up and out of the pan. If you turn off the engine while trying to fill it, the fluid will come pouring out of the fill hole (don't ask me how I know).
To get the fluid level correct, the transmission has to be at the correct temperature, which is between 35 and 50 degrees Celsius. The attached instructions say to use a fancy diagnostic tool plugged into the OBDII port to measure the temp, but an IR thermometer aimed at the bottom of the transmission fluid pan does the job just as well, and you can get an IR thermometer for $25 at Harbor Freight Tools. You'll need a way to pump the fluid up into the transmission fill hole, because all of this is done from below. A $15 garden/bug sprayer from Home Depot works fine if you take the spray nozzle off of the end of the hose, or you could buy a $7.99 hand pump from Harbor Freight.
After that, it's just a matter of pumping the fluid in, letting the transmission warm up to the correct range, which will cause the fluid to expand and come back out of the fill hole, and then plugging the hole when the fluid as at the correct temp.
Hmmm... the pdf instruction file is too large to allow me to attach it. I'll post a link to it and hope that works. Here's the link: http://jaguarforums.com/forum/attachment.php?attachmentid=7780&d=1297182563
If that doesn't work, just go to this thread on jaguarforums.com. The instructions are in post #25, although the rest of the thread is a good read, too.
That looks like one of the places on 2nd Street, near Main. I normally stay on North Pennsylvania, close to NMMI. (Weather getting good there at the moment, but also getting good here in Central Florida).
BTW, Nice XK8 (or is it an XKR, too far for me to see).
