Nav system will not boot up
rrazin777
I was away on a 7 day trip and had my 2011 Genny Sedan Tech in the garage the entire time. I got back and drove the car and the nav system will not boot up. It says the nav system is starting please wait. Is this normal because the system has been out of satellite range too long. Is there a reset procedure I can follow? All the other functions work on the head unit minus the nav.
Thanks for any help. I am afraid to pull the a battery cable to reset the system.
Thanks...
Try turning it all off with the off/volume button beside the cd slot. Then turn it back on with same button. If that does not work you may have to disconnect the neg. battery terminal in the trunk for 3 minutes or so then reconnect. Computers can sometimes do strange things and a complete reboot may fix it. I know that laptops sometimes will not boot up or will hang and thay can be rebooted after unplugging the power cord and then taking the battery out for a minute or so then replacing the battery and they will then boot up and act normal again. Not sure why but it works.
Thanks...
I just had a similar situation with my 2012 3.8 w/premium. Not only did I lose the nav system, but I lost the entire audio system. No radio. no XM, no iPod, no backup camera, nothing but the Genesis screen on the display. I pulled into a parking lot and shut of the entire car and restarted it. No solution. So then I shut off the car and opened the driver's door, shut it and restarted the car. Everything worked! Why? I have no idea. Next time it freezes, I am going straight to the dealership so they can see it.
Mmmm whenever i want to boot up my system for re install the windows i am make some changes in computer BIOS setup and select the CD/DVD as the first boot device and boot up my computer for installing the windows..............
