The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Interested in these too if you get a chance can you ps them too?
Thank you and your car looks great! What offsets and tire sizes are you running? Also how much lower than stock are you?
Thanks, I don't recall the exact offsets. I want to say the rears are +35 maybe. The shop that I purchased them from determined which offset would work in the rears which are 20x10. I think stock wheel offsets are like +45 but again, I don't recall. My car is lowered several inches. If I recall correctly, I think I'm almost maxed out or close to it on the coilovers as far as how low they can go.
Not much of a fan of the color but here you go...
Ok thank you that helps out alot. I know I can get them in more aggressive offsets, I just wanted to see what you had on ur car, so I can make a decision. I know one guy was running a 20x11 +29 which was a little too aggressive for me, but atleast I know as long as I go less aggressive than that it will fit. I have one other question, do you know if the sedan has camber adjustment from the factory? I know my Genesis coupe has alot of camber adjustment in the rear but none in the front from the factory. I'm wondering what if any you had to buy in order to dial in your camber (if any)
JASTYLR.....well ive said it before but its worth repeating. thats the nicest ginney ive seen. i have the same car w/4.6. id love to copy the look. will the lowering void the warranty?
I have 20" Vertini Hennessey's on my car with a staggered fitment. Here's the real thing on my car:
Another forum member, newman, just purchased a set of them in 19" as well.
Folks,
FWIW....keep in mind, if you drive an R-Spec, the brakes are bigger and may eliminate many of the wheels on the market. I'm waiting for some TSW Nurburgrings 19x9 to be shipped to me. Off set of 35MM. I was advised that any wheel with a lip will not work. That fact alone eliminated most wheels. I'm putting 275/45 Bridgestone 050A Pole Positions on it. They are 1.5 inches wider than stock 19's. That fact killed all but a few choices. I'll post some pictures when job complete. I'd also wager, since the R-Spec Suspension is different, lowering springs may be some time off.(?)
Newman,
I'm 98% sure I read that you used 35mm offset wheels and they did work, correct?
Advance Auto Parts have spacers 5/16 of an inch thick. I used them on my Sonata and they did did go over the after market concentric rings, although not much. My problem may be the wider tires hitting the front of the front wheel wells behind the headlights during a full locked wheel turn.
