Polen
Here's a document that I've been working on to give to service. I planned on waiting until my 90 day checkup, but due to the pinging problem I have an appointment for this Friday.
Let me know If I should change my wording or technical terms. Thanks.
Genesis Problems
Genesis Problems
- Cruise Control “Set” indicator stopped illuminating.
- Auto windshield wipers mode does not work well at night (sometimes wipes) have to switch to low speed. Not sure if this is a limitation of the system or not, but the manual said nothing about using at night.
- At 1700 miles noticed engine made faint detonation noise (ping noise) during acceleration. I had 1/8 tank of gas so filled up with 93 octane. Got on the road and accelerated and ping noise was no longer present. Ran two tanks of 93 octane with no ping sound, so I tried another tank of 87 octane from Shell and within 15 miles the ping noise came back. I only put 5 gallons in the car, so I drove it to 1/8 full and then filled with 93 octane from Shell and the ping noise never went away. I’m now on my 2nd tank of 93 octane from Shell and the pinging is still present and more noticable, even my wife noticed it.
- Sometimes when I push the accelerator to perform high acceleration the car slowly goes, other times it is very responsive when pushing the acceleratory and plants you in the seat. This can be annoying; I push the accelerator and wonder how fast I’m going to go this time. Most of the time it gets up and goes with great acceleration, sometimes it slowly accelerates, so I push the pedal more and it never really takes off, but slowly goes and increases speed. Update: I have noticed that when it is slowly accelerating that it did not drop down to a lower gear.
- Rear wheels look like they are leaning in slightly. Check wheel alignment please.
- Rear passenger driver side seat belt was in the center seat position. I had to pull on center seat belt connector and move to the correct position, but could you look at it to see if it needs to be remounted under seat.
- Is there an update to the NAV Map, seems to be over 4 years old? Street that are 4 years old are not present on map.
- Any news on Bluetooth streaming?
