Penzoil Mail In Rebate / Warranty Offer.
gameday22
Florida
Hi all,
For those of us who use Penzoil here is a nice way to get an oil change for free after MIR, courtesy of Penzoil and their Warranty program. I waited to post this to make sure they sent the $ as promised, received the refund from them in about 5 weeks. All you have to do is register your vehicle:
http://www.pennzoilwarranty.com/our_warranty/
Our Warranty
The Warranty that lets you change your oil on your schedule.* As long as you're within the owner's manual guidelines, you're good.* Other conditions apply.
Please read this important information about our warranty before you enroll.
WHAT DOES IT COVER?
Up to 500,000 miles or 15 years (whichever is first) if you exclusively use Pennzoil Ultra™ motor oil
Up to 300,000 miles or 10 years (whichever is first) if you exclusively use other Pennzoil® motor oil products (i.e., Pennzoil® Conventional, Pennzoil® High Mileage Vehicle®, Pennzoil Gold™ and Pennzoil Platinum®)
HOW TO QUALIFY
Your engine must have 60,000 miles or less and have been manufactured within the last 60 months
The Pennzoil Lubrication Limited Warranty takes effect 6 months after your first eligible purchase of Pennzoil® motor oil
MAINTAINING THE WARRANTY
Change your vehicle’s oil and oil filter at least as often as recommended by the vehicle manufacturer
Replace the air filter and air cleaner elements, maintain the emission control system must and follow scheduled engine maintenance in accordance with the vehicle’s manufacturer recommendations
Update your oil change records online at least once every twelve (12) months, even if no oil change has taken place, on this website
Remember: Save all service receipts in order to be eligible for reimbursement under this warranty
PLEASE HAVE THE FOLLOWING INFORMATION AVAILABLE
Vehicle Identification Number (VIN)
Odometer Reading
Date of Vehicle Purchase/Lease
Date of First Pennzoil® Oil Change
Enjoy :)
Penzoil runs ZERO risk of a claim and 100% chance making profit off you using their product. This Tau engine will be the last thing to go down on a Genesis. The weak link in modern vehicles is electronics. Multiple hot and cold cycles play havoc with solid state electronics. Think about it. would you put your Ipad or I phone in an oven or a freezer? Not, electronic gremlins
plague most high end vehicles well before 200,000 miles. ;)
The engine may fail, but do you have to prove it was caused by the oil in order to collect the Pennzoil warranty? I haven't read the details, so I am just asking, but that is usually how those things work.
Regardless of the warranty, for those who use Penzoil it's a good way to get an oil change on them. I have used their oil now for a long time and have had zero problems with the engine on any of my cars. Oil, just like the products you use to wash and wax your car are a personal preference and this just happens to be mine....thought to share it with others who also use Penzoil.
Pennzoil Lubrication Limited Warranty Terms and Conditions
Covering vehicle engine parts for do-it-yourself and installed customers by SOPUS Products.
SOPUS Products warrants you, the vehicle owner or lessee whose name appears on the front of this Pennzoil Lubrication Limited Warranty document (“you”), that it will repair or replace, at its option and at its expense, the engine parts listed below, that fail on account of engine wear or which experience abnormal wear, because Pennzoil® motor oil failed to provide proper lubrication. The Pennzoil Lubrication Limited Warranty includes all the terms listed below. This Pennzoil Lubrication Limited Warranty is free. No one may charge you a fee for it, or change it, or make any exceptions to its terms. This Pennzoil Lubrication Limited Warranty is available on Pennzoil® motor oil to customers who change their own oil or have their oil changed by an installer, automotive center, commercial fast oil change facility, gasoline service station, or auto dealer and who use Pennzoil® motor oil.
THIS PENNZOIL LUBRICATION LIMITED WARRANTY IS IN LIEU OF ALL OTHER EXPRESS OR IMPLIED WARRANTIES, AND THERE ARE NO OTHER WARRANTIES OR REPRESENTATIONS AND NONE SHALL BE IMPLIED. ALL WARRANTIES ARE LIMITED TO THE TERMS AND DURATION OF THIS EXPRESS WARRANTY. SOPUS PRODUCTS SHALL NOT BE LIABLE FOR ANY INCIDENTAL OR CONSEQUENTIAL DAMAGES RESULTING FROM THE USE OR FAILURE OF THIS PRODUCT, HOWEVER CAUSED. SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED LIMITED WARRANTY LASTS,OR THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE LIMITATIONS OR EXCLUSIONS MAY NOT APPLY TO YOU. THIS PENNZOIL LUBRICATION LIMITED WARRANTY GIVES YOU SPECIFIC LEGAL RIGHTS, AND YOU MAY ALSO HAVE OTHER RIGHTS, WHICH VARY FROM STATE TO STATE. THIS PENNZOIL LUBRICATION LIMITED WARRANTY DOES NOT EXTEND THE VEHICLE MANUFACTURER’S LIMITED WARRANTY.
How Long Does the Pennzoil Lubrication Limited Warranty Last: It takes effect six (6) months after your first eligible purchase of Pennzoil® motor oil. As long as you do what it says in this Pennzoil Lubrication Limited Warranty, your vehicle’s Listed Engine Parts will be covered against lubrication caused failure from the time you were eligible for this Pennzoil Lubrication Limited Warranty program as follows:
Up to 15 years or 500,000 miles (whichever is first) – if you exclusively use Pennzoil® top portfolio level full synthetic motor oil (i.e., Pennzoil Ultra™)
Up to 10 years or 300,000 miles (whichever is first) – if you exclusively use other Pennzoil® motor oil products (i.e., Pennzoil® Conventional, Pennzoil® High Mileage Vehicle,® Pennzoil Gold,™, Pennzoil Platinum® and Pennzoil® Synthetic Blend Dexos1™)
Please note the following:
You may change your level of warranty protection at any time as long as your vehicle is within 60,000 miles and within 60 months old.
Once your vehicle has more than 60,000 miles or is more than 60 months old, you may only change from 15 years/500,000 miles warranty protection to 10 years/300,000 miles warranty protection. The change becomes effective as soon as you stop using the Pennzoil® top portfolio level full synthetic motor oil and start using the other Pennzoil motor oil products. This change cannot be reversed.
Product names may change or a product may be substituted or discontinued without notice at SOPUS Products’ sole discretion.
Class 1 diesel engines are covered when in compliance with proper SOPUS Products product use and the Terms and Conditions of this Pennzoil Lubrication Limited Warranty.
Vehicles used, registered or leased for commercial, agricultural or competition purposes do not qualify for the Pennzoil Lubrication Limited Warranty.
What Engine Parts Are Covered (“Listed Engine Parts”):
Pistons & Piston Rings
Oil Pump & Timing Chains
Crankshaft and Bearings
Rocker Arms and Pivots
Rods
Rod Bearings
Push Rods
Cam Shaft and Bearings
Valve Stems and Guides
Wrist Pins and Bushings
Turbo Bearings
Valve Lifter
Cylinder Lining or Bore
Distributor Drive Gear
Timing Gears or Sprockets
What You Do as Part of the Pennzoil Lubrication Limited Warranty Program:
Enroll online at www.pennzoil.com (except California residents)
Service your vehicle’s engine with a Pennzoil® motor oil, in the service classification and viscosity grade that is appropriate for your vehicle as recommended by your vehicle manufacturer.
SOPUS Products requires you to change your vehicle’s oil and oil filter at least as often as recommended by the vehicle manufacturer.
Replace your vehicle’s air filter and air cleaner element at least as often as your vehicle manufacturer recommends, and maintain your vehicle’s emission control system in accordance with your vehicle manufacturer’s recommendations.
Follow all scheduled engine maintenance recommendations by the vehicle manufacturer.
Update your oil change records online at least once every twelve (12) months, even if no oil change has taken place, on the Pennzoil Lubrication Limited Warranty website so you can maintain your coverage (except California residents).
The warranty covers engine parts..."that fail on account of engine wear or which experience abnormal wear, because Pennzoil motor oil failed to provide proper lubrication"
In order to be covered by the warranty:
  • SOPUS Products requires you to change your vehicle’s oil and oil filter at least as often as recommended by the vehicle manufacturer.
  • Replace your vehicle’s air filter and air cleaner element at least as often as your vehicle manufacturer recommends, and maintain your vehicle’s emission control system in accordance with your vehicle manufacturer’s recommendations.
  • Follow all scheduled engine maintenance recommendations by the vehicle manufacturer.
  • Update your oil change records online at least once every twelve (12) months, even if no oil change has taken place, on the Pennzoil Lubrication Limited Warranty website so you can maintain your coverage (except California residents).
There is no way in hell that one can prove that an engine part failed because Pennzoil failed to provide proper lubrication, assuming their was the proper amount oil in the crankcase and assuming the service items are followed.
No, the engine isn't likely to fail because of their oil and if it did maybe you will or wont be successful with filing a claim.......but YES your getting 5 Quarts of oil for free after rebate. That is all ! :grouphug:
